![]() | Home > Africa > Puma 2.4TDCI and 2.2TDCI Gearbox oils. |
Peter-S Member Since: 09 Apr 2013 Location: Zambia Posts: 6 ![]() ![]() ![]() |
Hi Guys,
I'm not an oil fundi but thought I would share some of my latest findings with you. 2010 2.4TD gearbox oil, Castrol BOT 130 M. Capacity 2.2L. The LR dealers in RSA recently supplied me with Castrol Manual BOT 328 for the gearbox, this is probably a replacement or an upgrade to the 130 M. When searching the Castrol websites I couldn't find anything concerning Castrol BOT oil but did come up with their recommendations for the LR 2.4 and 2.2 gearbox oils which are as follows. 2.4TD, Syntrans Multivehicle 75W-90, 2.2L capacity. 2.2TD, Syntrans Universal Plus 75W-90, 2.4L capacity. These two Syntrans and BOT oils are probably exactly the same or the latter might be a slight improvement, perhaps someone who is more knowledgeable on this topic could elaborate. What is most interesting is the oil capacity between the 2.4TD and 2.2TD which has been increased to 2.4L. this will in all likely-hood bring the oil level up to the level of the filler plug. (A gearbox upgrade in disguise) ![]() Your thoughts or findings would be of great value. Thanks Peter |
That's interesting! I did read a chap on this forum topped-up his 2.4 gearbox to the level plug, and had a positive effect on gearchange smoothness... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
After draining my oil and topping up with the correct amount I have definitely noticed an improvement in shifting gears but the clonking and clattering noise became far more pronounced once the gearbox got hot.
Today I have topped the gearbox up to the filler plug level and have taken a long test drive, gear shifting is the best its ever been and the clonking and clattering is far less than ever before, even disengaging reverse gear is a lot easier. I decided that if I could drain almost 5L of oil out of the box last week then an extra 300ml shouldn't cause any harm considering that the box had already done 32000 km without any leaks. I'll post an update next week and let you know how its going. ![]() |
