Home > Maintenance & Modifications > Applying Waxoyl with underbody accessories? |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 |
looks neater if you remove them first then refit the shiny stuff over the nice clean black under side, or you could spend time cleaning of the overspray from your steering guard and the once silver diff guards. and weeks later still be spotting bits when you get to look from diferent angles and it looks scruffy and your frustrated and feel like you have made your pride and joy look worse not better and and and ........................
take the bits of i didn't and i wish i had |
24th Jan 2010 12:20pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
I left my guards on. There's overspray on the steering guard. Personally I don't mind - I don't really want it to look shiny anyway because it betrays the fact that I don't to enough off road.
However, if anything you have makes it harder to get the coating on then you should remove it (they couldn't do behind my diff guard, for example) so I'll do that myself when I replace it. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
24th Jan 2010 10:24pm |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 |
Once again - thanks for the advice!
25th Jan 2010 6:42am |
