![]() | Home > Technical > has my air-con been swiped/swapped |
Could be November 2009 if that is the date stamp which sounds about right on a 2010 model
Photoguy1510 Member Since: 02 Apr 2013 Location: Wellington Posts: 25 ![]() ![]() ![]() |
No more than likely you have lost your refrigerant through the shaft seal. You need to run your aircon on a regular base to keep the shaft seal lubricated if its been standing for a long time chances are good that its leaked through. Now that you have run it the seal will be wet an even if they check it wont find the leak. At least its under warranty so they can fill, it insist they recover and use a fresh charge. R134a is not chemically stable an when it leaks out it leaks out as individual gases not R134a this affects its refrigerant properties as essentially it contaminates itself when it leaks. Some will tell you its not that important but your discharge temperature will be higher and defenders don't need any extra heat in front of the radiator. Cooling capacity will also be reduced and lets face it its not great to begin with. It is good practice but cost money so companies take the shortcut, worst is they charge the systems by looking at the sight glass on the receiver, perfect way to over charge the system which will lead to a failed compressor down the line, after warranty has run out. Fresh charge weighed in is the only way it should be done.
Don't forget run the ac every 2 weeks for 10 min cost nothing and it wont leak its refrigerant, more important on older units as they had leather seals but just as critical in modern systems with carbon based seals. 2013 Orkney Grey 110 SE on order should be here on 20/04 |
