Home > Td5 > Defender 90 TD5 CSW 1998 (S)
Page 2 of 2 <12
MAF sensor is attached to the hose leading from the big square air box up near the bulkhead.
It has a cable going to it. You will need a small screw driver to prise the thin silver metal clip out of the plug before you can pull it off Thumbs Up
Post #227431 15th Apr 2013 11:57am
bob neville
^^^^ beat me to it !
Easy to find.
locate the airbox at the back of the engine. Then looking from the front you will see a large pipe coming from the box on the RH side. Near the airbox there will be a plug on the top of the pipe. If you just want to disconnect the MAF then pull this plug out. To remove the MAF you will need to undo the jubilee clip to part the pipe.
2013 Defender 90 CSW - sold
Post #227432 15th Apr 2013 12:00pm
johnnyd
Thanks chaps.....most helpful, i may not get a chance until the weekend now.... Sad
Post #227433 15th Apr 2013 12:04pm
johnnyd
OK here is the latest.....Looks like my EGR is in circuit, so not blanked off, found the MAF and have disconnected it for now, do i also have a MAP sensor to check ?.......edit....found it http://www.landyzone.co.uk/lz/f67/removing...98286.html
Post #228457 18th Apr 2013 8:18am
TR51
France 2014 Defender 110 Puma 2.2 SW Corris Grey
The MAP sensor is the black oval plastic (held on with two Allen bolts) just bulkhead side of the EGR valve... I used compressed air, but electrical contact cleaner also works if you've got it.
There's a good write up here: http://www.landyzone.co.uk/lz/f67/removing...198286.htm
Thumbs Up
Post #228460 18th Apr 2013 8:36am
johnnyd
Well it deffo drives better with the MAF disconnected........just off to get some carb cleaner to clean the MAP. Can the MAF be cleaned ?
JD
Post #228473 18th Apr 2013 9:37am
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
You can clean your MAF with carb cleaner too just make sure its good and dry before restarting the engine. 2005 Td5 90 XS
Steve
Post #228496 18th Apr 2013 10:52am
johnnyd
WOW.......cleaned MAP and MAF with carb cleaner......BIG difference...the MAP sensor was really cruddy.......looks like i still have the EGR in place, so blanking kit ordered from irb Smile
Post #228546 18th Apr 2013 1:24pm
Page 2 of 2 <12
