Home > Maintenance & Modifications > Replacing rear bulkhead plate with a bar. |
I've got the Mud Stuff Bulkhead Removal Bar. It's a great but of kit and was really easy to fit!
http://www.mudstuff.co.uk/bulkhead-removal-bar.html An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
18th Apr 2013 6:28am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
I'm about to do the same on my 90. I had an old rear tub that I scrapped, so I kept the top C channel of steel that came off of that bulkhead.
I'm going to chop (the bulkhead) down to the right height, and with the remaining C channel, and my salvaged one, weld it into the shape (which should be something like \______/ ) then re-rivet it back on. |
18th Apr 2013 6:42am |
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 624 |
I removed my entire rear bulkhead and replaced it with an original LR (bulkhead removal bar), the manufacturers were selling a few on ebay that were rejected for cosmetic imperfections, I paid £80 for the bar (retail price can be £150+) and it took the best part of a day to fit, cutting the bulkhead out wasn't that bad, a 4" disc grinder with a thin cutting disc and a reciprocating saw and then a sanding disc to clean the rough edges up. The only difficulty was, you are supposed to remove the rear van sides so you can get bolts through to secure the top of the bar, I forced a nut in the gap and fit the bolt from the underside up (sounds strange but I can post photo's to explain if you want) all in all in "Haynes manual rating" I would say 3 spanners, gives loads more room for seats to go back especially if you fit the mud rails. Highly recommended
Hope this helps Optimists say the glass is half full.. Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
18th Apr 2013 7:15am |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1423 |
+ 1 for MUD. I have one and fitted a couple into other peoples. Easy job, will take about 4/5 hours and looks like it was manufactured that way. Excellent service from MUD
18th Apr 2013 11:36am |
ClaireWright Member Since: 12 Oct 2012 Location: Warwickshire Posts: 609 |
Just ordered my removal bar from mud,came next day and will be fitted soon
18th Apr 2013 4:29pm |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 |
Thanks folks, I'll budget in a MUD bar & seat slides but can bow look for a van with a rear bulkhead knowing it can be replaced. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
18th Apr 2013 9:27pm |
