Home > Maintenance & Modifications > Side window demister
chipmunk
2012 Defender 90 Puma 2.2 HT Oslo Blue
Just had my first run in the wet with newly done mod' to demist..............great, can really recommend. Only cost £4-5 for the aquarium tubing plus the annoyance factor of removing dash, but did the double washer jets thing and refurbished the wiper rack/cable while it was out. Also anyone looking to find Delphi Freedom battery to replace oem, Delphi don't do batteries now. Have gone for Bosch.
Post #228090 17th Apr 2013 10:50am
Tiger
What did you use for the vents?
Post #228092 17th Apr 2013 11:12am
chipmunk
Original vents still in place. Ran tubing from heater box straight to dash end. The mod has been covered many times on this forum. Effectively does the job of the MUD UK mod but lots cheaper.
Post #228099 17th Apr 2013 11:19am
Tiger
Sorry I mean vents for the dash end or is it just a hole?
Post #228105 17th Apr 2013 11:25am
chipmunk
Right now they are just holes as I've been looking for a trim to finish it off. Maybe there is a LR part as in the new Defender, that one is square with louvres. Will look into that.
Post #228108 17th Apr 2013 11:32am
megatoad
United Kingdom 2006 Defender 110 Td5 XS CSW Zambezi Silver
Hi Chipmunk
Sounds a great idea to me especially for my TD5
Have you got some photos?
How did you plumb into the air supply, T off the windscreen demister feeds I assume? He who dies with the most toys wins Smile
Defender 90 & 110, S1 80", Disco 1, S111 88
LRSOC & CVLRC
Post #228114 17th Apr 2013 12:00pm
chipmunk
Afraid it's all back together again and I didn't photo it but if you do a search with "side demisters" on here it will come up with a couple of versions of how to do this. The MUD UK kit includes new vents with T's off to the sides. Others say that the kit works well (as it should at over £100) and would be much simpler to fit. But with a bit more effort you can run tubes from the heater box below the centre console to the dash ends and have the same result for £5.
I used silicone to seal the joints at both ends. Aquarium tubing 3/4ins is heavily ribbed and sort of screws into holes you drill into the heater box and dash ends, then apply silicone to seal. IMO taking air supply from the heater box may give slightly higher volume of air than 'sharing' air to the screen vents by 'T' piece. But up until now I've not even had the heater fan on full and the side windows stay mist free.
Post #228121 17th Apr 2013 12:23pm
