Home > Puma (Tdci) > Rear seat wont latch
Dieselhead
Hi,
My rear 60/40 have a problem
The single seat wont latch up & you can just fold it down. The back rest that is. The base is ok
Think its been like that since I have had it. MOT soon so its got to be sorted
Before I go looking at it, would anybody know if its a simple fix etc
Thanks Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #227907 16th Apr 2013 7:19pm
ickle
Lube the mechanism and make sure the base is properly slammed down before locking the backrest in position.
Keith
Post #227909 16th Apr 2013 7:22pm
Happyoldgit
Helps if you try and push the release back down a ways as sometimes they don't return especially if not lubed. IIRC there is also an allen key grub screw in the mechanism under the plastic trim cover that can work loose and cause the back to lock upright too. Steve.
http://forums.lr4x4.com
Post #227959 16th Apr 2013 9:04pm
Greener78
2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
I just paid the local stealer an hours labour to remove a piece of plastic the size of a 1p coin from the mechanism. Part of the plastic trim had broken off. On the upside all the seats latch like new.
Might be worth popping the cover off if lubricating doesn't do the trick and see if anything is jamming the mechanism..
Post #230318 24th Apr 2013 10:10pm
