Home > Puma (Tdci) > 140bhp?
x-isle
140bhp?
I know that Topix can be wrong on many occasions, however, I've just realised that my 110 is stated as having a "2.4L DOHC HPCR DSL 140PS PUMA" engine.
I'm guessing this could just be the engine that is provided by Ford and is just listing it's capability before LR dump their map on the ECU. I think in the older Transits, the variable turbo was only an option on the 140bhp version. I'm sure it is on my Transit based Motorhome with the 140bhp 2.2 engine. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #227393 15th Apr 2013 8:57am
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
I don't think that 1PS equals 1BHP... My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #227396 15th Apr 2013 9:16am
x-isle
It doesn't, but it's near as damn it.
1bhp is 1.01ps. Craig Rogers
2007 Puma 110 XS
Post #227402 15th Apr 2013 9:31am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
ford supply many transit engines with all different powers and im pretty sure that they dont supply a transit with 122hp but that said i would asume it is down to landrover to have the desired power they want out of it after all said and done look what tuning does to vehicles its only different stage of map simular to stage 1 td5 and then astage 2 td5 just different gains Thumbs Up
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #227406 15th Apr 2013 10:04am
Caterham
just a thought.....should it be KW not PS.....
I'm bhp doesn't = 1kw but off the top not sure which is greater (just a thought).
Post #227407 15th Apr 2013 10:04am
x-isle
1 bhp = 0.74kw if I remember correctly.
I think the standard Transit when they had the 2.4 Puma engine only had 90bhp, there where then various options of which 140bhp was one, the main difference was the introduction of the variable turbo which both 2.4 and 2.2 Puma Defenders have.
This is why I think the engine is probably supplied as the 140bhp variant. Craig Rogers
2007 Puma 110 XS
Post #227416 15th Apr 2013 10:23am
big steve
im 100% certain they only have 122hp from the factory and also the proof is here on the forum BAS has proved on many 2.2 cars that they only have 120ish hp ?
Post #227417 15th Apr 2013 10:28am
Vera
2009 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
On most of the earlier 2.4 engined variants you'd see something like "90T250" on the front doors... mine had "125T250" for instance.
My understaning is that the first number is the PS (90/125/140 etc) and the second is the bodystyle.. 250 being a MWB/Medium Roof... '09 SVX #200
'10 Morphy Richards.. I mean Prius
Post #227461 15th Apr 2013 1:48pm
Porny
Site Sponsor
Its a Ford 140PS spec engine - which means it has the higher flow injectors, the Variable Geometry Turbo with ERA, oil spray jets (for the pistons) and a couple of other features.
The Land Rover calibration is 122bhp (in theory - but you will never see this on a rolling road).
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #227464 15th Apr 2013 1:54pm
x-isle
Bow down As I thought!
Thumbs Up Thanks for clearing it up! Craig Rogers
2007 Puma 110 XS
Post #227467 15th Apr 2013 2:04pm
