Home > Technical > TD5 rocker gaskets. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6074 |
When i fitted the new head to my 90, twice... i just used some gasket sealer either side of said rocker gasket... no leaks at all
14th Apr 2013 10:43am |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 555 |
Earlier td5 gaskets do have a smaller Half moon section if you've fitted the earlier type it will leak like anything !
Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
14th Apr 2013 11:36am |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1413 |
I only did the half moons with RV silicon and have had the same result |
14th Apr 2013 12:31pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5816 |
You must be the lucky ones!. Would an a later gasket fit an ealier head (mine is an AMC head)? 1999 Defender TD5 110
14th Apr 2013 12:54pm |
IIRC the rocker cover bolts have to be torqued down to about 7 ftlb, which is not very tight, if you over tighten them the gasket will deform and you will get leaks.
I like the gasket sealer idea though... |
14th Apr 2013 1:34pm |
