Home > Td5 > Crankshaft pulley.... rubber bushing disintegrated
Anyone had the rubber damper bit disintegrate on a Td5? mine went the other night, you can rotate the grooved pulley bit forward and back on the back of the main pulley.
Is there a repair kit for it? Or am I better to just weld the two pieces together? (and thus save spending a fortune for a new one)
Typical, i gave my spare one away a while back.
Post #226819 13th Apr 2013 1:20pm
LR90XS2011
Diesel Jim
can I recommend you buy a new one as quickly as possible and fit it, it acts as a harmonic damper that stops the crankshaft from getting stress fractures DEFENDER 90 TDCI XS,
Post #226833 13th Apr 2013 2:05pm
dorstsmith2
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
DAMPER CRANK SHAFT TD5
LHG 100580
Post #226836 13th Apr 2013 2:13pm
TD5_dan
2001 Defender 110 Td5 CSW Java Black
Fairly common, no repair as far as I know. Agreed get it changed ASAP. Unfortunately not cheap and only go for a genuine if you want it to last! 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon
1970 Series 2A hard top
1960 Series 2
1972 Series 3
Post #226882 13th Apr 2013 5:19pm
I'll have a gander around and see what I can find. cheers all.
Post #226886 13th Apr 2013 5:34pm
