Home > Camping, Caravanning and Holidays > Mud flaps and Towing
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Hi all, will be returning to towing a caravan again this year, probably a Sprite 540. I've read elsewhere that when towing the mud flaps , due to the airflow between Defender and caravan, can be forced into the rear wheels and worn accordingly. Is this true and is there a way to avoid it? Whistle LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #226086 10th Apr 2013 5:10pm
Sonarmender
England 2015 Defender 90 Puma 2.2 HT Corris Grey
I don't want to state the obvious, but what about leaving the Tin Tent at home Rolling with laughter Rolling with laughter You only have one life, live it....forget the cost.
90XS Hardtop
Post #226090 10th Apr 2013 5:22pm
Yeah, that's true, it depends how fast you go..... A friend of mine smelt burning rubber and his tyres had ate his mud flaps Laughing
Post #226091 10th Apr 2013 5:24pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
Never heard of it before myself, but I'd say better s bit of wear on the mud flaps than having mud / stones / exhaust soot making a mess of the front of of the van! Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #226092 10th Apr 2013 5:24pm
Laurie
I've never had a problem with my D90 but I have to tie up the flaps on my Dakar.
A 110 or 130 shouldn't have any problems.
Post #226093 10th Apr 2013 5:27pm
If this is a problem, how about the old-timers' trick of a chain or cord from the bottom of the mudflap back to the rear crossmember.
Post #226103 10th Apr 2013 6:07pm
Laurie
A year or so ago in the dark I backed over a high kerb and pushed a mudflap onto the tyre.
Driving forward dragged it into the tyre.
It sounded as if a very expensive repair was needed to the back axle.
I drove ten miles home before I looked at the back end.
Was I relieved to see it was just the flap.
About 2-3" was missing.
I've got a photo somewhere.
Post #226107 10th Apr 2013 6:27pm
K9F
Pam W wrote:
Never heard of it before myself !
I have! Thumbs Up Piccys too!
http://www.defender2.net/forum/topic7742.html?highlight=mudflaps If you go through life with your head in the sand....all people will see is an ar5e!!
Post #226114 10th Apr 2013 6:53pm
WelshGas
That's a good idea Blackwolf, but on a 90 the rear mudflaps are mounted on the rear cross member. A metal strip fitted with bolts to the mudflap would stop the flap being forced onto a wheel, although I do have bumperettes fitted so could have a chain to them, but if this isn't a problem in normal practise then nothing needs to be done as long as I don't back over a curb. Rolling with laughter LANDYWATCH
Post #226123 10th Apr 2013 7:17pm
WelshGas
Ordered some Aluminium strip to place on the inside of the mudflap to prevent it being forced onto the wheel when towing, just in case. Thumbs Up LANDYWATCH
Post #226382 11th Apr 2013 5:09pm
WarPig
How are you attaching it? Im sure ive seen someone selling mud flaps on ebay that come with a strengthening bar?
Post #226420 11th Apr 2013 7:11pm
WelshGas
Hi Warpig, it's 20 mm wide so I'm going to experiment with a strip the length of the mudflap with a U bend at one end to clip over the bottom of the mudflap with a self tapper SS screw to secure. At the other end there will be a Right angle bend that will be secured by the middle bolt that secures the mudflap bracket to the bottom of the rear cross member. Forgot to mention the vehicle is a 90. Whistle LANDYWATCH
Post #227254 14th Apr 2013 6:31pm
WarPig
Understood Thumbs Up
Photos when done? Thumbs Up
Post #227284 14th Apr 2013 7:25pm
WelshGas
Will do. Wink LANDYWATCH
Post #227292 14th Apr 2013 7:53pm
Romadog
I used to do a lot of miles for my previous job in 3 different aged 90s towing an 18' trailer. The mud flaps cracked along the embossed line below the bracket and if not noticed early, decided to part company. I was accused by my dealer of off roading it, but as I worked for their sister company, they knew my use of it and warranty was always done, especially when it was a part that had been replaced previously and therefore was under Parts Warranty. friends following me would always comment on my flapping mud flaps when they followed me on the motorway. The bottom did wear a little if I remember, but I think that was on the one with the little wheels fitted, hence mudflaps closer to the ground when doing serious towing.
Post #227296 14th Apr 2013 7:57pm
