Home > Technical > 90 losing power |
If you've had it serviced the level and concentration of it should hopefully have been checked. As we are heading into warmer weather and it's just a pint water will be fine in my opinion!
Pink/blue it doesn't make any real difference in my book, but blue is easier to spot in the event of a leak/seap from pipework. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
10th Apr 2013 9:28pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8580 |
Sounds like the engine management system has been working fine.
Bet you did not see any noticeable rise in temperature on the chocolate fire guard of a L R temp gauge? What age/ mileage on vehicle? Top up with water will be fine as long as coolant concentration level is correct before next cold spell! Advice used to be do not mix coolants as there might be a reaction between the different coolants. How true or not that is I do not know. Fingers crossed it is a loose hose clip/ split hose but be prepared to If it is more serious. We got LR to contribute BUT it still hurt. Brendan |
11th Apr 2013 7:16am |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
11th Apr 2013 12:07pm |
td5 commercial Member Since: 20 Mar 2011 Location: Nr Taunton, Somerset Posts: 18 |
Fekete, don't fall into the trap of assuming its the head gasket, I have had one where the egr cooler split and leaked internally, had exactly your symptoms, remove egr cooler from rear of the head and pressure test it, very easy to do, and the part was quite cheap. hope this helps (even though last time I posted on here your were being a proper nob!) |
11th Apr 2013 1:03pm |
11th Apr 2013 5:23pm |
11th Apr 2013 5:34pm |
11th Apr 2013 5:38pm |
