Home > Technical > 90 losing power |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
http://www.defender2.net/forum/topic17174.html?highlight=speedo
Does this help? 2005 Td5 | 90 Station Wagon | Tonga Green |
10th Apr 2013 3:35pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
10th Apr 2013 3:38pm |
No worries - hopefully that's all it is. 2005 Td5 | 90 Station Wagon | Tonga Green
10th Apr 2013 3:40pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20282 |
EGR stuck open could cause a lack of power too. Although likely to put up the MIL or log a DTC though which I assume you've not had. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
10th Apr 2013 3:42pm |
10th Apr 2013 3:55pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8580 |
Small loss of coolant can cause EMS to kick into limp home mode. Temp drops and then full power again.
Brendan |
10th Apr 2013 5:08pm |
10th Apr 2013 5:44pm |
IF, and I repeat if you have a small loss of coolant do not be fobbed off with main dealer saying it is a weak pressure cap.
Yes they will replace pressure cap foc, however you may have a more serious problem such as a head gasket job. IF you just loss power under load, I.e. hills/towing briefly for less then 30 seconds and NO apparent temperature rise with a small loss of coolant I would strong suspect head gasket. Yes I have that tshirt! Brendan |
10th Apr 2013 6:36pm |
Didn't look like you were losing power when you were up my backside coming onto the estate yesterday morning
Hope you sort it out mate An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
10th Apr 2013 7:10pm |
10th Apr 2013 7:35pm |
10th Apr 2013 7:36pm |
10th Apr 2013 8:13pm |
Karlos, I'd fill it up with coolant, preferrably bright blue as if you do have a leak it'll be easier to spot!
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
10th Apr 2013 8:41pm |
10th Apr 2013 9:02pm |
