Home > Technical > Low Range Use |
Christian Member Since: 23 Feb 2013 Location: Doha Posts: 66 |
Well it happened exactly the same way to me, and a few months later here I am, with a completely broken transfer box mount I reckon the mount was dead anyway, the range selection only being a consequence of it... I don't know how to avoid it though... Chris |
10th Apr 2013 11:16am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17336 |
Pretty much the same setup as I have, although I had to fit the internal bits as well! The genuine transfer lever housings for High/low/difflock are rare as hens' teeth now! As you say, eventually customer power caused the difflock to be available as an option again. Mine is an '02 and came from the balck years when none of it was fitted. Also as you say, you get the best of both worlds with a retrofit - ABS/TC only - ABS/TC/Difflock - Difflock only, and of course all lights etc work. |
10th Apr 2013 11:34am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8003 |
teaching the LRE way avoids this too. i dare say the sand is the main culprit in wrecking linkages out there? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
10th Apr 2013 2:29pm |
otter-spotter Member Since: 11 Feb 2013 Location: Scotland Posts: 37 |
Phil C already covered this, but if you have done any kind of move between high and low I agree it's always a good idea, once you have just moved off, to dip the clutch and either push (or pull!) the selector to make sure it has engaged properly.
Also, it's a really good idea to get familiar and confident with using the diff lock. If you are changing a wheel, especially on any kind of slope, once you lift a wheel you have effectively removed the handbrake. The diff lock will at least mean you have spread the braking ability over 2 wheels. One at the front and one at the back. Really need to chock everything too. Same idea if parking up on a slope offroad (or icy road), if you don't have the diff lock on and one of the wheels is in slippy stuff the motor might just slide away! On a steep slope probably best to put it in low box (check it really goes in!), diff lock (make sure the light comes on), handbrake on and in gear (put it in reverse if facing down hill ?) - you are giving yourself a fighting chance of it staying put.. Sorry if I'm stating the obvious but it's suprising how many people forget just what diff lock does and how it can work to your advantage and, sometimes your disadvantage. 300 TDi 110 CSW |
14th Apr 2013 6:02pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
My difflock lever is a tad stiff, any recommendation on the best lube, or just spray some WD40 on the linkage?
Thanks BM52 |
14th Apr 2013 6:41pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
low range is good when the trailers on aswell as 3 dumpy bags.... so thats 3.5 tonnes
in the snow i was flicking the CDL in all the time upto 50ish mph. |
14th Apr 2013 7:04pm |
Once you lift a rear wheel this will be the case. Lifting one front wheel with the handbrake on, both back wheel will still be held with the handbrake. However lift one back wheel with the handbrake on and the vehicle in gear and it will stay put. Good practice however is to chock it securely before lifting anything. If you can't chock it (why not?), then engage difflock, gear and handbrake before lifting anything. |
16th Apr 2013 11:09am |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 |
I tend to use low range on a daily basis - albeit briefly. Thanks to a helpful suggestion by a forum member, I use it to get up my extremely steep driveway.
The only alternative is to slip the clutch and rev like a madman trying to avoid crashing into the house or the gate on the side of the house. In low, I just let the 110 pull itself up the incline... kind of like on the LR Experience track, except there is no mud and I don't come whoosing down the other side of the hill. |
17th Apr 2013 8:56am |
Not sure this has always been my experience but I'll try it again on some rollers on a hill - I could be wrong. Either way unless I'm on pretty flat ground and chocked I'm always wary of taking a wheel off. I always consider that any situation where one wheel can turn (so without diff lock engaged) could be a situation where it rolls. Land Rover used to state that engaging diff lock was part of wheel changing procedure - not sure if they still do. There was an incidence of a guy taking a half shaft out when parked up on a steep drive - that didn't work out well either! 300 TDi 110 CSW |
17th Apr 2013 6:48pm |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 |
Must do mine to test it out! Good for crawling in long slow traffic queues. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
17th Apr 2013 9:06pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
I have driven loads of Land Rovers over the years and the worst I have had is where a Discovery hadn't selected Low in over 5 years and that needed a wiggle to get into Low and Diff lock- but it went with not much hassle.
Once a week is a bit OTT. I use it weekly on mine, but that is when I need to, but sometimes gone several months without using it and not got even slightly stiff. I don't grease/ oil the linkage- simple reason why- The linkage doesn't have any constant moving parts to wear anything away, if you put oil and or grease on it the moisture will attract sand, dust and dirt which will then go solid. Glyn |
17th Apr 2013 9:44pm |
