Home > Maintenance & Modifications > Brake caliper split pins |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
There not that big about 1/8 ish but just get a selection there only pence
9th Apr 2013 9:19pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Did the new pads not come with new pins, springs and split pins?
Have you checked the old ones- mine were put through and only about 1 5 degree bend was put on them so would have been re-usable if the set I bought didn't have replacements. I think I even have a set of spares in the car. Glyn |
10th Apr 2013 3:34am |
If you do not have split pins to hand you can use r-clips to hold the pins in place. Works a treat...
10th Apr 2013 6:59am |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 |
None supplied in the boxes! Off to Halfords this lunchtime to buy some.. ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
10th Apr 2013 9:56am |
