![]() | Home > In Car Electronics > speakers |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20644 ![]() ![]() |
10cm and 13cm are your only options really. 10cm gives IMO a very good improvement and 130 just a touch more power again. But the 13cm's will be a pint to fit! Personally I haven't bothered as the power difference isn't IMO worth changing for s the 10cms are more or less a straight swap..
If you'd like any links / suggestions for what to actually go for please let me know. ![]() ![]() Steve TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Baggie Austin Member Since: 16 Mar 2013 Location: Birmingham Posts: 102 ![]() ![]() ![]() |
Thanks, I was thinking the 10 would be my best option.
Dont want to mess around with fitting to much to be honest, I may consider a sub at a later date. Some links would be good. I remember my old renault 19 when I was younger, I fitted two 15 inch jbl subs, a rockford fosgate amp, and 6x9s jl audio. It cost loads and the car was only worth 500 quid, the lot got nicked. ![]() |
Oh dear.
![]() http://www.justkenwood.co.uk/car-audio.aspx/kfc-s1094-speakers ![]() Click image to enlarge If you want to have your grilles straight on exactly rather than at an angle you will need to do this: ![]() Click image to enlarge Like I did but I am fussy and you may not want to bother with this. All the fixings are supplied as standard with the speakers. My speakers are the same model as in the link just mine are the older design grille now. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
Thats great Steve, easy fit is what I am looking for, those kenwoods are decent sounding then?
Will I need a spacer or are these ok? Cheers |
They have a good frequency range yes. And in future if you want a little more highs try some aftermarket tweeters or more lows a sub. They are good all round IMO never pushed them hard because they get too loud then again I prefer powerful bassy music on a lower volume than high volume can't hear yourself think type. And no spacers required with these. They were what I wanted to avoid as I don't like the stuck out look.
Feel free to drop me a PM if you want any other help. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
You are a diamond mate, cheers |
Welcome mate.
![]() ![]() ![]() β½οΈπ’οΈβοΈπ§°πͺ |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1959 ![]() ![]() ![]() |
I fitted vibe slick 6's to the rear along with a set if tweeters this weekend had to trim a bit away but easy job. Sound is good next I plan on fitting larger to the front and a hideaway amp and sub
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
