Home > Maintenance & Modifications > Up rated braking
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Up rated braking
I think now that the engine conversion has been done successfully I need to look into updated braking any one have any ideas ? Ebc or something else
Answered on a post card would be good Smile
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #225192 7th Apr 2013 1:09pm
AndyS
I'm not sure if they already have this (I doubt it) but fit braided hose. That way all the stamping power you put on the pedal will transmit to the callipers. There's slightly more maintenance in that you have to make sure they're not fraying but otherwise they're a relatively simple upgrade. It does change the feeling you get at the pedal but you get used to it.
Post #225199 7th Apr 2013 2:42pm
Depends how deep yopur pockets are willing to go. Have a look at the braking upgrades on Alive's page. Thumbs Up KEEP CALM AND Drill ON
Post #225200 7th Apr 2013 2:50pm
I have a set of military "armoured" spec brakes... the discs are huge. same diameter as the standard ones, but about half as wide again. came off of a salisbury axle I had on a previous 110.
Calipers are standard 4 pot, but with a wider spacer in the middle of them. don't give any extra stopping force, as a 6 pot caliper or larger pads would, but certainly stops the brake fade.
Compared to a standard vented front disc:
Post #225202 7th Apr 2013 2:56pm
big steve
Hmm ok cool cheers for the info Thumbs Up
Yes I have already got braided hoses so I need the improvements beyond these Confused
The alive discs are fine but don't think I can rap 35 inch simex round them Big Cry
I need something that will still fit a standard 15 inch rim Neutral
But stop me better
Cheers for your help steve 2015 2.2 tdci hardtop xs
Post #225220 7th Apr 2013 4:07pm
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
Hi Steve, what is the problem that you are trying to overcome? Do you need more feel, more effort when cold, prevent fade? Various upgrades options, but would be useful to know the specific problem you are trying to overcome?
Regards
Mark.
Post #225266 7th Apr 2013 6:15pm
big steve
I just want to be able to stop a lot better tbh I was thinking along the lines of ebc green stuff or yellow stuff pads with slotted and dimpled discs
Really just wanted to know over people's opinions
It's nt easy to stop 2.5 ton from 100+ mph Neutral
Post #225272 7th Apr 2013 6:26pm
EBC green is what you want if you go that way. Yellow ultimax IIRC they are aftermarket standard quality. I was thinking of fitting just EBC green pads to mine instead of Genuine but I'm still not sure. Some say they are great others say Genuine are better. Confused KEEP CALM AND Drill ON
Post #225280 7th Apr 2013 6:35pm
Mjibex
Hi Steve on my old slightly modified V8 ninety, I went for
Standard vented front discs
Standard rear discs
Mintex 1144 pads front and rear As per (http://www.motorsportworld.co.uk/frame-detail.asp?PAGE=/mintex-brake-pads.htm
Remove spring from front to rear compensator, ie 50/50 front/rear split (careful braking required on corners - practice 1st)!
This setup worked fine for me on the high speed stops; your truck is slightly heavier, so if you wanted you could go for Mintex 1155 (esp if your front discs are not vented). Pads also do not wear out as quickly in the mud or sand (they used to be about double price though).
My opinion of some other bits available (without extreme cost):-
Change all the brake fluid not just a quick bleed - you could go for a hotter brake fluid (used to use AP555 - I think was called - it is more hydroscopic through so needs to be changed more often - not great on off road maybe - tech might of moved forward here).
Vented discs - very good - remember to clean after off roading - more easy with open wheel design - airline easier than water.
Groved discs - good for scraping glazed pads, but if you give it welly fairly often, or use in mud/sand the pads will not glaze anyhow.
Drilled discs - pointless IMHO - just provide a point for cracks to start and an extra place for stones to get stuck and destroy the pads (esp. on 4x4).
Just my 2 pence worth!!
Regards
Mark.
Post #225286 7th Apr 2013 6:52pm
big steve
Cheers thanks for that I will look into it
That's why I thought slotted and dimpled would be better
Steve Thumbs Up 2015 2.2 tdci hardtop xs
Post #225287 7th Apr 2013 7:06pm
leeds
Might be worth a chat with Dve Round at Llama 4x4.
He makes a lot of braided brake hoses for other companies.
Me? I know nothing about updated brakes. Hiwever would suggest you talk to someone like Dave who has specialised in this area
Brendan
Post #225296 7th Apr 2013 7:29pm
