Home > Puma (Tdci) > Injector timing adjustment (near Worcester ?)
rossy
In an attempt to cure my intermittent 'pinking' rattle I have had excellent advice from you guys.
Fuel wise it makes no difference whether I use cheap or premium fuel with or without 2 stroke. Power and mpg are not lacking and I've changed fuel and air filter recently. The EGR is fine with nice quiet 'chukkas'. Its had four oil+filter changes in 26k km. But on long journeys I still get this annoying rattly pinking sound on moderate acceleration.
On Lorryman's advice I was at the dealer today for an injector learn and a pilot correction relearn. According to the dealer the 16 digit hex code was correctly assigned to the EMS and there was no evidence of fuel rail pressure being too high. They talked about running it through various 'cycles' on their diagnostics. They said its spot on and runs beautifully. But of course on the way home it was exactly the same !
This leaves one thing. I'm convinced the injector timing is slightly out and I want to adjust it a bit as others here have done. In July we're going to Malvern, Worces. again for two weeks on hols (long story). I'd love to get Alive or BAS to do this adjustment but York and Grimsby is too far really. But I will if I have to !
Does anyone know if there's any good LR tuning specialists within an hour of Malvern, say B'ham or Oxford for instance ?
Thanks !
Post #224891 5th Apr 2013 5:19pm
Porny
Site Sponsor
Did the dealer do everything in the correct order?
Injection pump learn/re calibration
Injector Numbers
Injector Piolt learn (this must be done last)
I would not change the timing from standard - and in my opinion, although I'm sure tuners will try and dissagree - you should not (and in fact there should be no need) to have the timing adjusted.
Engine timing is critical, and Land Rover spend millions developing and mapping the optimum timing (and there is more than just one map that most people adjust). But apparently people tweaking in a workshop can make it better??? The fuel system, set up and control is critical to the running of a Puma Engine. And any tweaks to Pulse width or timing on a Torque based strategy is wrong.
More often than not, issues like this can actually be down to injectors themselves, with a fault that only shows up under a certain load/condition.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #224896 5th Apr 2013 5:34pm
rossy
thanks Porny
Actually the dealer said they hadn't done a relearn before so the info in your post makes me suspicious. I see you're in Sutton Coldfield and looking at your tuning credentials is this something you would be interested in checking out ? I don't want 500nm though ! Laughing I just want to get a diagnosis from someone who knows this kind of stuff inside out which you obviously do . I can always phone IRB and book it in nearer to July if thats OK.
Post #224905 5th Apr 2013 6:04pm
Caterham
Rossy,
as mentioned on other posts I couldn't recommend enough that you pull the MAP (and MAF) sensor(s) out and give em a clean with carb cleaner. for the sake of 2 mins its a no brainer in my opinion.
Thumbs Up
Post #225045 6th Apr 2013 10:11am
K9F
Re: Injector timing adjustment (near Worcester ?)
rossy wrote:
Does anyone know if there's any good LR tuning specialists within an hour of Malvern, say B'ham or Oxford for instance ? Thanks !
If you're in a fix go here, they are an excellent independant with a great reputation! They will sort you out! I still use them on occasion and they're two hours from me! Ask to speak to Steve and explain your problem. They have sorted another couple of people out in a 'fix' last minute if you read the feedback.....
http://www.james-french.co.uk/
Dealer feedback....
http://www.defender2.net/forum/topic2222.h...mes+french If you go through life with your head in the sand....all people will see is an ar5e!!
Post #225046 6th Apr 2013 10:15am
keith
I also had exactly same heavy pinking issues . Whilst getting the turbo hose replaced after the recall I told them to upload the 2013 software . Bingo - no more pinking issues . Same silly rev probs and gear changes but much smoother . Can't wait to get to BAS though .
Post #225049 6th Apr 2013 10:32am
rossy
Caterham - thanks I'll do that. Thumbs Up
K9f - I'll give those guys a look in they sound great (and they look a bit posh !) Thumbs Up
Keith - yours is a 2.2 I think. I asked the dealer the other day and they said there were no software upgrades for a MY11 2.4 on the system so I'm guessing the 2.2 has already needed one !
Post #225140 6th Apr 2013 9:30pm
keith
Yes I'm a 2.2 for my sins . Good luck with your repairs .
Post #225143 6th Apr 2013 10:02pm
Jc700
Pakistan 2015 Defender 90 Puma 2.4 HT Zermatt Silver
Hello There Rossy,
I am currently facing the same problem with my defender. Did you manage to fix this issue? If yes, can you please share how you went about fixing it.
Post #1017162 2nd Dec 2023 6:35pm
