Home > Maintenance & Modifications > Puma screen washer issues |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
Welcome, William
Have a shifty at this thread: http://www.defender2.net/forum/topic18055.html Hopefully it'll help you Some folks have also one an upgrade... http://www.defender2.net/forum/topic17143.html Welcome to the Scottish branch of Defender2.net Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
5th Apr 2013 11:21am |
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 624 |
I had a lot of problems with mine a while back, I'm not sure if the puma is the same as the TD5 but under the bonnet tucked away in the passenger side corner, just before the washer pipe goes through the bulkhead is a little plastic non return valve, this was sticking, I removed it and put a small piece of pipe in its place and never had that problem since. I'm not saying that is your problem but well worth a look. Optimists say the glass is half full..
Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
5th Apr 2013 11:33am |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 |
Thank you, i had a wee search but didn't come across that thread. I was in about it last night and didn't see a non return valve. Ill have a look at pulling it off. William
5th Apr 2013 12:10pm |
5th Apr 2013 12:14pm |
