![]() | Home > Technical > Help needed - front propshaft broken off! |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Hi all
Fortunately not mine, but buddy phoned me just now with apparently large problem. Stuck in field 30 miles away. Td5 propshaft broken off at transfer box end! Can't engage high ratio although drives in low ratio ( propshaft rotates from diff end by the sounds of it) Any ideas what might have gone wrong? I'm suspecting some sort of seizure in transfer box? He's only had it for three days so a bit gutted obviously. Need to sort out some sort of recovery now. Ta DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html Last edited by d j hutton on 1st Apr 2013 12:46pm. Edited 1 time in total |
Thanks for the reply.
It's the front one, I forgot to say. Much as I suspected re getting it home, problem is know to work out what's 'gone' Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
DJ
Not the high/low linkage seized or broken is it ? Can't see why that would break the prop but may explain why he can't get into high ratio. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
If Hi range isn't available then it's only really a tow home job then.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
Remove the front proshaft.
Jack up each front wheel to see if it turns. If so, should be OK to attempt to drive or tow out. ![]() |
I would agree with that
![]() DJ - in a field 30 miles in which direction, maybe one of us is close to him and could lend a hand/help ? Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
That's what I suspected, but I'm thinking something more catastrophic to break the propshaft off. He's over New Milton way and it sounds like AA might be sorting out a recovery for the time being. On the bright side if its a transfer box failure then it might be an opportune time to upgrade to a disco ratio one ![]() We,ll see what the AA man has to say. Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 ![]() ![]() ![]() |
Obviously if he does try to drive it after removing the prop he needs to have diff lock engaged to get any drive to any of the wheels.
Thanks for the replies chaps, turns out it probably isn't as bad as originally thought.
The UJ on the front of the transfer box appears to have collapsed which allowed the prop to come away. yoke on the transfer box is broken and spider had it. So tying to source parts for it today, hopefully its possible to buy the front yoke an spider as separate parts instead of a complete prop! The lack of drive in high range turned out to be user error ![]() DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
