Home > In Car Electronics > iPhone 5 compatible Head Unit search.
iPints
United States 1994 Defender 90 300 Tdi CSW Epsom Green
Had a little search this morning and cant find any head unit that is compatible with the iPhone 5..... Sad
I know it will bluetooth to almost any of the bluetooth systems but i quite fancy using the headunit to charge the iPhone too.......any thought or advice....
Post #223651 31st Mar 2013 10:28am
It maybe worth contacting the / a manufacturer direct and asking as I would expect that there is a firmware update released out that will make it compatible. Not sure on the lightning connector though. Although there is adaptors available. Perhaps that is worth a try and relatively cheap too.
Thumbs Up No Guts, No Glory.
Post #223652 31st Mar 2013 10:35am
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
My Kenwood has a USB connection and I can charge my iPhone 5 from that using the sync cable and still have audio streaming over Bluetooth.
Finding a head unit with an integral lightning connector is gonna be pretty tough I reckon.
Post #223664 31st Mar 2013 11:41am
Martin
Site Admin
Don't most iPod compatible headunits use the standard iPod cable now, so the lightning cable supplied with the phone is used to connect it up?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #223665 31st Mar 2013 11:52am
I wouldn't bargain on it Martin although I guess different bands vary. Most as far as I know use the 30pin plug but seeing as I don't have either a ultra modern HU not iPhone 5 I can't be sure. Personally I've not seen anything to do with the lightning plugs yet on any I.C.E. system but happy to be proved wrong.
There is these available though:
http://www.ebay.co.uk/itm/New-8-Pin-Lightn...19da5a9fd4 No Guts, No Glory.
Post #223666 31st Mar 2013 11:58am
Martin
Site Admin
Steve, agree that older HUs (like the one I have in my 90) use their own connectors/adapters to the wide 30-pin iPod/iPhone connector. I was under the impression that (most of?) the newer ones used a USB port for iPod/iPhone Confused
Using an adapter in the car is clunky, have to it with mine to charge the iPhone and it constantly detaches Big Cry  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #223668 31st Mar 2013 12:04pm
Cakey
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
My alpine unit that came with the car, works and charges iPhone 5.
Just use the USB to lightning cable
Post #223669 31st Mar 2013 12:15pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
My unit somehow does give an error when I plug my iPhone 5 in.
Post #223673 31st Mar 2013 12:40pm
Cakey
What is odd with the alpine, the phone works for calls etc via Bluetooth.
For music and charging you have to select source USB .
Post #223675 31st Mar 2013 12:54pm
Most HU's have a female USB socket and in my case video jack and audio jack too. These then plug into the Kenwood specific IP300 Ipod Audio Video cable which then connects to the iPod / device.
This will be useful: Kenwood iPod / iPhone Compatibility List No Guts, No Glory.
Post #223683 31st Mar 2013 2:40pm
barbel jim
my Alpine headunit works fine with the dedicated Ipod lead. Just put and adapter on taking it down to the smaller size plug for the Iphone 5. Can play standard Ipod as well. Not sure if it dose everything it should as Yes got an Iphone 5 but don't know how that works Whistle All the gear no idea Thumbs Up
Post #223687 31st Mar 2013 3:19pm
RobKeay
My parrot works ok with my iphone 5.
Post #223693 31st Mar 2013 4:27pm
Martin
Site Admin
Since Apple allowed 3rd partys to read digital audio over the USB then headunits have gone down the USB socket only, not requiring the audio/video separately.
See the Kenwood iP101 cable, etc Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #223696 31st Mar 2013 5:15pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
iPhone 5 works fine with all my JVC head units (one in each car of different ages/models). The oldest one has a JVC iPhone lead that you have to use but it works fine with the adaptor. The other two just use the USB cable so the normal charging/syncing cable works.
Full control over music playing from the head unit (skipping tracks, track/artist display etc...) as well as charging.
I chose the JVC in the first place as they were the only supplier publicly claiming 100% compatibility with iPhone for both music playback and hands free use. http://www.yorkshireoffroadclub.net/
Post #223704 31st Mar 2013 5:55pm
davew
Post #223705 31st Mar 2013 5:56pm
