Home > Technical > Alarm Fault - ? AS10 unit |
Is the main car battery charged?
30th Mar 2013 1:01pm |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
I've had problems witht the AS10, green terminals, but you ought to check all the fuses first. Some under the dash and some under the driver's seat.
Merlin |
30th Mar 2013 4:34pm |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 |
Thanks both,
All fuses removed, checked, and replaced, no problems there. No problems with the charge in the batteries. I disconnected the battery all afternoon but the fault is still there when I reconnected. All the other electronics in the car seem to be working fine, even turns the starter over when you advance the ignition but engine immediately dies as with the immobiliser being active. |
30th Mar 2013 6:44pm |
The person with the best knowledge is Lorryman. Try and contact him by PM. In the meantime, it does seem to be related to being left idle. Fob batteries? If you need to get at the AS10, then prepare yourself for a fight! LR put that on the production line and build the car around it.
Merlin |
30th Mar 2013 7:01pm |
Cheers Merlin, i've PM'd Lorryman
I know it seems likely that it is linked to lying up, but the fault is the same regardless of which of the three keys is used. Also noted now the interior light isn't doing anything. The more I look at it the more I think the alarm unit is at fault! Anyone have a spare AS10 |
30th Mar 2013 9:21pm |
