Home > Puma (Tdci) > Defender heater panels connections
dgardel
Italy
Are the heater elements in series or parallel???
I mean:
parallel =
series =  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #21805 10th Jan 2010 9:20pm
dgardel
Italy
Re: Defender heater panels connections
I mean:
parallel =
series =
I mean R1 is the bottom part of the seat and R2 is the backrest, so R1 AND R2 are ONE seats
Nobody know or can check?? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #21820 11th Jan 2010 8:00am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Complete wiring diagram for the seats sent in a PM. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #22035 13th Jan 2010 9:00pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
dgardel - believe they're in series as if one part goes the whole lot malfunctions. You can check easily by unplgging the connectors and using the continuity tester on a multimeter. On mine the continuity test was fine on the seat base but failed on the backrest.
Post #22118 14th Jan 2010 5:47pm
BBSJK
England 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
I have had a new passenger seat base under waranty as it had stopped heating up. The back rest was still working fine. So must be parallel?
Jonathan No the other left . . .
Post #22193 15th Jan 2010 7:41pm
dgardel
Italy
cobs???
BBSJK???
Big Cry Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #22207 15th Jan 2010 11:24pm
