Home > Puma (Tdci) > Cleaning the engine bay
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Is it safe to just open the bonnet and jetwash the inside if the bonnet and engine? I have a snorkel installed on my 2.4 TDCi.
Post #220948 21st Mar 2013 8:03pm
GUM97
I do it regularly (not on Defenders) but make sure you cover up anything electrical! I'm sure somebody will be along soon who's done it before so can give some advice! Thumbs Up An engine to TDi for!
Post #220953 21st Mar 2013 8:14pm
TooTall
United Kingdom 2004 Defender 90 Td5 HT Tonga Green
Not sure if its the right thing to do but on my TD5 I just remove the acoustic matting, run it a short while then spray a solution of traffic film remover prior to jet washing. I then finish off by spraying GT85 everywhere; I suspect that someone will be along shortly who actually knows what to do... Rolling Eyes "Ease your worries, Clear-up your woes,
Go into your garage & put stuff into rows."
Post #220954 21st Mar 2013 8:15pm
HardCharger
I'm curious about this topic as I just did 2 runs, few weeks apart, in volcanic ash. I was told that this stuff corrodes metal and most especially electrical connections. This being the case, I was told a good pressure wash will not hurt my 2.4 Puma but I'm still kind of chicken to try it out until I hear from folks who can give pointers and tips. The truck is my daily driver and I cannot afford such an expensive break down.
I was also advised to spray a mixture of diesel and oil after the wash to coat the engine in a slippery film so that future dirt will not stick to the engine but rather the film and will easily be washed off then just repeat the process.
Thoughts and advice appreciated.
Thanks!
Post #392643 26th Jan 2015 8:54am
Cheshire110
Again, no particular knowledge but I HAVE done it before, no problems.
Just tried not to blast anything electrical too hard! Gave it a good spray with fairly liquid & water mixed together beforehand- worked well. Cheers, David
Post #392644 26th Jan 2015 9:05am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I done mine after I brought it as it was a bit mucky!
Just stay away from the ecu on the bulkhead, and around the turbo,
Afterwards give all the electrics a spray with WD or something similar.
Been fine with no issues 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #392666 26th Jan 2015 11:18am
x-isle
If you have an adjustable pressure washer even better as you can turn the force down for certain areas you don't want to hit with high speed water. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #392676 26th Jan 2015 12:05pm
zone30
+1
Also better to use hotter water and have the engine warmer (not hot!) so the water quickly evaporates.
WD40 I can understand but a diesel mixture ... Shocked
Post #392744 26th Jan 2015 6:29pm
Naks
IMHO, don't jetwash the engine bay.
I know a few guys who had engine malfunctions afterwards, due to MAP sensor failure and other water-related issues. --
Post #392748 26th Jan 2015 6:48pm
zone30
I've been in 80cm of dirty water. Low pressure clean water doesn't seem to pose much of step to me... Question
Post #392752 26th Jan 2015 7:14pm
JAY BOY
Wales
Ive always done all my cars with a pressure washer. Turn the lance pressure down to the minimum and leave the engine running. it gets a bit steamy but never had a problem.
It cant be any worse than driving through a ford
Post #392762 26th Jan 2015 7:43pm
sweepc
2013 Defender 90 Puma 2.2 XS CSW Santorini Black
^ I've done it quite regularly with the 300tdi I also left the engine running. Not tried it with the puma yet but as long as you don't blast anything electrical it should be ok
Post #392775 26th Jan 2015 8:21pm
CatherineF
I know someone quite well who does a lot of professional detailing.
They suggested I should use an engine cleaner, detailing brush and just a hose not a pressure washer. 2015 Audi Q3 Quattro S Line Plus 184 TDI Stronic
2010 90 SMC Over Land Nero Edition - Santorini Black Metallic (Now Departed)
Post #392805 26th Jan 2015 9:27pm
Cuthbert
Perhaps a degree of common sense required? I know it's not a fashionable topic and UK schools are on a mission to beat it out of any pupil using it.
But seriously, lift the bonnet and look at some of those electrical connections and components - do you really think it's a good idea to turn on a high pressure jet of water and drive water into them?
Remember this vehicle was designed by Ford and TATA cost accountants - not the designers of HMS Astute, which I understand can safely be submerged in pressurised salty water.
Post #392820 26th Jan 2015 9:51pm
Grouse
I have done it and won't do it again ! - Censored the fuel potentiometer on a Range Rover - cost me Ł400 tracing the resulting misfire fault and replacement of parts
Post #392851 26th Jan 2015 10:54pm
