Home > Maintenance & Modifications > Torquing with a ring spanner
ZeDefender
Please does anyone have any tips or tricks on how to correctly torque M8 bolts with a ring spanner? I need to "permanently" bolt on my turbo and 2 of the 3 bolt heads aren't accessible even with a small torque wrench. I'm going to be using Nord Lock washers, so I don't want to cock it up Whistle
Matt
Post #220467 19th Mar 2013 5:16pm
Usually done with something like this, or better still the full ring version (of which I cannot immediately find a photo).
Post #220471 19th Mar 2013 5:40pm
Laurie
Find the torque in foot/pounds or cm/Kgs
Take the length of the spanner as a fraction of the unit you're using and divide into the weight.
Then use a spring balance to torque up.
e.g. If the torque required is 15lb/ft and the spanner is 8" between centres (2/3rds of a foot) then divide that into the 15 pounds. Equals 22.5 pounds on the spring balance.
Simples (almost Rolling Eyes )
Post #220476 19th Mar 2013 6:15pm
ZeDefender
Thanks guys.
Laurie - that's very clever...now I need a compact spring balance Confused Tell someone you love them today because life is short.
Post #220478 19th Mar 2013 6:35pm
v8steve
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Rimini Red
crow foot spanners are a good idea. should be able to buy a 13mm it's self to fit your m8 bolts if access allows.
nord-locks on the way, posted today Mr. Green 110 xs s/wagon
s3 swb soft top
Post #220486 19th Mar 2013 7:19pm
ZeDefender
Brilliant Steve - many thanks.
Pardon my ignorance Messrs Blackwolf and Steve but could you use a crow foot with a torque wrench? Wouldn't it move/mess up the pivotal force? In any event, I fear I can't squeeze anything in there apart from a ring. It's probably why LR failed 3 times to stop the studs falling out (that and the fact they really need re-tightening after a few heating/cooling cycles).
Matt Tell someone you love them today because life is short.
Post #220490 19th Mar 2013 7:32pm
If you attach the crowfoot so that its axis is perpendicular to that of the torque wrench any inaccuracy will be negligible.
Post #220579 19th Mar 2013 11:58pm
ZeDefender
Doh! Thumbs Up
I'll look today to see if I can get one in there... Tell someone you love them today because life is short.
Post #220584 20th Mar 2013 6:51am
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
Crowsfeet are pretty good, but one way is to torque a nut up to the required torque, then put your ring spanner on it and see how tight it is. Then do the turbo one up to the same
Post #220633 20th Mar 2013 1:18pm
ZeDefender
That was my original thought but each of the three bolts require my hands, body and legs etc. to be in completely different positions (under, over, behind, in front) Rolling Eyes
I've probably got a few days until the washers arrive, so perhaps I can try a few suggestions out Thumbs Up Tell someone you love them today because life is short.
Post #220638 20th Mar 2013 2:11pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Post #220809 20th Mar 2013 11:10pm
ZeDefender
Yesssssssss!!!!!
Now to find one...
Many thanks Thumbs Up Tell someone you love them today because life is short.
Post #220818 20th Mar 2013 11:53pm
smb
Hi All,
The method mentioned is the most common for hard to get to nuts/bolts.
You do have to be careful when using an adapter like a Crowsfoot or a closed end spanner as you need to take into account the length from the centre of the nut/bolt to the centre of the Torque coupler(doesn't matter what size as it is to the centre.
To help give you as close an accurate Torque setting you use a formula as follows:
Y=((TxL)/(L+E)) where Y will be the new reading on the Torque Wrench, T is the required Torque on the bolt/nut, L is the length from centre of connector in Torque Wrench to centre of Handle Grip and E is the extension distance(centre of bolt head to centre of connector.
i.e.. If the bolt has to be torqued to 40lb/in, the length of the Torque Wrench is 300mm and the length of the adapter is 50mm then you will need to apply a force on the handle of 34lb/in. As you can see it is a big difference.
This can only work when the centre of the bolt is in line with the centre of the adapter and the centre of the torque wrench or if the wrench is at 90deg to the adapter. If the Wrench is at any other angle to the Adapter then you have to adopt a different formula where the angle value has to be included.
Hope this helps.
Steve
Post #220901 21st Mar 2013 2:33pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
For ZeDefender- new here http://www.srtorque.com/Products/SystemsandTools/STindex.html Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #220906 21st Mar 2013 2:54pm
smb
Just been talking to one of my Design Engineers who up until this point I thought was very clever!!!!!
It turns out he takes the easy route and goes on the following link:
http://www.cncexpo.com/TorqueAdapter.aspx
A lot easier Whistle
Post #220907 21st Mar 2013 2:58pm
