Home > Technical > Puma EGR valve contamination.
Page 3 of 3 <123
CyberCharlie
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
How difficult is to replace it? I am quite good with DIY but i have very little experience with engines. The mechanic quoted some 250 pounds for parts and labour...
Post #218680 13th Mar 2013 4:39pm
All you will need is a Diagnostic tool to clear and DTC's and MIL light. (You may have neither at the moment if so you won't need the diagnostic too)
You will however need the appropriate section in the workshop manual:
And a Torque wrench to tighten the bolts to the correct NM Torque. (£20 roughly) other than that it's a case of having patience as it's a tight fit but possible. Also be sure to disconnect the battery before starting and work or removing the EGR electrical plug.
Removed EGR:
New EGR(Slightly different shape newer type)[You will also need the two new gaskets]:
New EGR vales available from LR I'd recommend Neil @ Shukers LR parts or Dan @ Duckworthparts. Both are excellent.
Not a difficult job but time consuming and difficult access hence garage charges. Perfectly possible though and worth it for the costs saved IMO. Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #218692 13th Mar 2013 5:43pm
Personally I myself bought a Diagnostic tool and Torque wrench as I didn't have either and did it myself saving £150 if I remember correctly. I also bought from Neil @ Shukers parts as he gave me the best price on the market. If you'd like his E-mail please contact me via PM. Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #218693 13th Mar 2013 5:46pm
CyberCharlie
thanks guys i'll give it a try
Ciao Smile
Post #218940 14th Mar 2013 10:15am
Caterham
are there known issues similar or otherwise with the new type egr valve Very Happy
or is it all sorted now?
Post #218988 14th Mar 2013 1:49pm
CyberCharlie
I have stuck my head under the bonnet to take a look at where the valve is... sure there is an awful lot of stuff between me and the EGR valve bolts. Do i have to remove some parts to access it or is it possible to take the thing apart directly?
Post #219040 14th Mar 2013 5:49pm
I removed nothing except for moving the axle breathers out of the way. That's the part that's difficult about changing the EGR it's the access to the bolts. there are four in total. One of the lower bolts is best acessed from underneath. But as I said it is a pain. Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #219086 14th Mar 2013 7:42pm
Oh forgot to mention. You will of course have to remove the EGR electrical plug as I mentioned before. Other than that and moving the axle breathers away that's about it. Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #219087 14th Mar 2013 7:43pm
ZeDefender
Like Charlie says - it looks quite daunting Shocked
How you did it, God only knows Thumbs Up Tell someone you love them today because life is short.
Post #219092 14th Mar 2013 7:54pm
Perseverance Wink Oh and determination. It helps with getting the old one off to think how much the **** cost you by packing up and forcing you to buy a new one in the first place.. Whistle Rolling with laughter Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #219098 14th Mar 2013 8:04pm
max peck
United Arab Emirates 2009 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Thanks Pete,
If you and bell-auto-services ever come up with a way of illiminating the whole system i would certainly be a customer.
The whole design concept of the EGR on the Puma engine is Censored (compared to none at all or the simple blankable system on the TD5 particularly for us non-european drivers).
I live in the middle east where the truck runs on low sulphur diesel as opposed to ultra low that you have in europe (many many times more sulphur). As a consequence the oil ,turbo, valves and crankcase are full of soot. No doubt the EGR valve is too (mine sticks open and shut too with all the usual fault codes). Furthermore i operate the truck in temperatures above 50 degrees celsius at times and cooling is a big issue. Its nonsence that the bloody EGR dumps heat into the already struggling cooling system through its cooler.
I would love to be able to remove the valve and cooler, bypass or blank them off neatly and reprogram the ECU to ignore the bloody EGR electrical connector input.
As an aside: Perhaps just regular cleaning of the EGR as opposed to buying a new one would keep it sticking?
Happy trails Guys.
Post #220517 19th Mar 2013 8:41pm
ZeDefender
You do have 3 possibilities (in order of cost):
1) Unplug the EGR valve and ignore the orange light (or clear it every 3 cycles with an OBD tool)
2) Fit a blanking plate with the correct sized hole so most of the exhaust gasses are stopped but the MIL doesn't go on
3) Get a remap from e.g. Pete with the EGR switched off (do this whilst the valve still closes...)
4) Get your own supply of better fuel.
Simples Wink Tell someone you love them today because life is short.
Post #220522 19th Mar 2013 8:55pm
nihwrd
EGR Change
Changed mine this weekend. Like many have said, not a technically demanding task (its only 4 bolts), but it is fiddly and time consuming, and I speak as a Sea King helicopter engineer. The most frustrating thing was dropping the bolts (often) and ten scrabbling around under the Landy to find them.
Perseverance and patience is the key!
Nick
Post #220529 19th Mar 2013 9:11pm
Re: EGR Change
Nick
You can say that again. Laughing Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #220531 19th Mar 2013 9:14pm
MD5
2009 Defender 110 Puma 2.4 SW Alpine White
Interesting discussion. Thanks to Pete for sharing his knowledge.
Post #220959 21st Mar 2013 7:25pm
Page 3 of 3 <123
