Home > In Car Electronics > 90 dash speakers
DOOFER
90 dash speakers
I'm trying to get some speakers for my 90, but i'm struggling to find some that are shallow enough to fit even with the adapter rings. was hoping for some focal integration, but just don't think they will fit. any suggestions?
Post #218857 13th Mar 2013 10:57pm
Are we talking a Puma Defender? And also what speaker size do you have? WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #218862 13th Mar 2013 11:11pm
DOOFER
sorry, its an early 1990 90 defender, they are 4" (100mm) fronts. i've bought the genuine land rover fitting rings, but with the wiper motor behind the n/s speaker, it doesn't look like i can get much in there
Post #218866 13th Mar 2013 11:16pm
Photo's would be ideal if you could? Also how deep are your adaptor rings shallow one's or deep ones? WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #218870 13th Mar 2013 11:27pm
Killer90
Site Sponsor
Buy 4 lots of spacer rings and fit two per side mate, does the trick and still looks like a factory finish Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #218880 13th Mar 2013 11:33pm
DOOFER
They are at work, but guessing the rings are only half an inch deep
Post #218881 13th Mar 2013 11:33pm
Killer90
Site Sponsor
My old 200tdi thats what i done on that Thumbs Up god i miss this motor Big Cry Big Cry
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  CSK Automotive
Post #218884 13th Mar 2013 11:36pm
barbel jim
Never had a problem with mine on standard LR rings. I'll try and measure the old speakers depth for you tomorrow. Just fitted 130Vrs vocals in mine. They are shallow mount with a tweeter and well worth the money. The tweeter alone will totally change the sound , if I could only do 1 mod to the set up that would be it. I'm sure the 100 mm focal K2 's are a direct fit or the coaxial integrated. Like I say I'll measure tomorrow for you and post some pictures when I'm on the laptop Thumbs Up
Post #218896 14th Mar 2013 1:14am
farmer giles
i can'y remember if i have spacer rings fitted on my 300tdi with infininty speakers; but i know i don't need them on my puma which has 4" rainbow mids fitted Thumbs Up
Post #218917 14th Mar 2013 9:58am
Killer90
Site Sponsor
Mr. Green yer the rainbows are pretty shallow aren't they Thumbs Up CSK Automotive
Post #218918 14th Mar 2013 10:00am
farmer giles
chris - i'll let you give daddy the model number as i can't find my paperwork anywhere Thumbs Up
(had the truck rocking to sandstorm by darude on the way to work this morning - epic trance to set the day up Cool
Post #218921 14th Mar 2013 10:14am
Try these: http://www.mudstuff.co.uk/products/in-car-...-deep.html
A few on that link please check the sizing that you'd require. As you can see there is a deep version. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #218946 14th Mar 2013 12:05pm
barbel jim
Measurements as promised. Old speakers were 50 mm deep, and fitted without a speaker ring.
I then put the original speaker ring and grill over the top to retain the factory finish.These rings are made on a slant which measures 15mm narrowest and 22mm at the widest point. So using these rings potentially you could get a 65mm deep speaker in no worries.
Heres a bad picture but will give you an idea
I have recently upgraded to 130 (5") focal VRS which are 48.5mm deep and again fit without speaker rings. They are infact a tighter fit on drivers side.
better sound due to larger cone,and are a tight fit. Biggest advantage is the addition of the tweeter which lifts the sound stage. Here is a picture showing what is behind that end cap. It is realativly easy to remove 4/5 screws then pull out and down. It has a couple of locating dowls.
Hope all that helps Thumbs Up
Post #218995 14th Mar 2013 3:25pm
familymad
where can i get the spacers from? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #220433 19th Mar 2013 2:59pm
Tiger
MUD sell them
Post #220439 19th Mar 2013 3:42pm
