Home > Maintenance & Modifications > Squeak squeak...
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Squeak squeak...
Anyone else have a squeaky seat in their Puma? The driver's seat in mine squeaks, I can't seem to get rid of it. It appears to be coming from the left side... enough to drive you bonkers if you're on a long trip.
The clutch pedal squeaks as well. I thought I'd sorted it - I doused the area that I thought was the culprit with WD-40, and it appeared to sort it for about 40 minutes...
Post #21790 10th Jan 2010 7:53pm
mse
Re: Squeak squeak...
Use some lithum grease on your clutch spring Thumbs Up Mike
Post #21792 10th Jan 2010 8:07pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
WD is great for removing oil and grease... as you say works for about 40 mins get some Grease on you're clutch pedal....that should sort it...as for you're seat lose some weight Rolling with laughter NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #21794 10th Jan 2010 8:11pm
K9F
Quick off the mark!
Reading the post I thought what an opportunity to make a joke about weight! Scrolled down and Fekete my old mucker beat me to it! Must have read my mind!
Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #21802 10th Jan 2010 8:55pm
fekete
Yes we seem to think on the same wavelength...any opportunity...and one of us are on it...you me or willy Snigger NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #21804 10th Jan 2010 9:04pm
eutek
Okay, okay - I get the hint. Time to slim down. Embarassed
Laughing
Post #21827 11th Jan 2010 9:02am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
I heard from someone else Whistle that it's the outside edge of the seatback rubbing on the car trim when the seat is in the "Built like a proper man position", a bit of silicon lube works wonders alledgedly Original Member Pie n Pea Club.
110 HCPU Tipper
Post #21828 11th Jan 2010 9:12am
K9F
Lardar5e!
Should the sillicon lube be applied to the seat or the lard 4r5e sat in it? Sent from a not so slim southerner!
Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #21832 11th Jan 2010 9:45am
fekete
Come on Guys i'm in the 17stone club and mine doesn't Squeak.... how big are you Guys Rolling with laughter you will be silicone lubing you door seals next to get in NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #21839 11th Jan 2010 10:49am
K9F
Strange Popping Sound!
Was wondering why whenever I get in or out of my Landy there was a loud 'pop.' Will be siliconing my doorseals forthwith!
Laughing
Anyone know how to spell silikone! Tried several variants now? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #21842 11th Jan 2010 10:58am
fekete
Its silicone... Me old Cider Chum NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #21843 11th Jan 2010 11:07am
K9F
Mouse! Squeek Squeek - Dead!
Once Upon a Time in one of our forces aircraft a mouse had been seen scurrying about. After attempts had been made to trap it with no success it was decided to take the aircraft up to a significant altitude have the crew on breathing air, open the door and let the little bu99er suffocate. And they all lived.......except the mouse that is! The end!
B & Q do a trap for mice, with regards to the altitude bit I think it's a non-starter but maybe a 'phall' at your local Indian followed by a long run may have a similar effect on the little blighter should it happen to be a mouse of course! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #21845 11th Jan 2010 11:29am
AndrewS
Take it to the dealer Thumbs Up
I was going to post "Take it to the dealer Fatty" but thought better of it Whistle Whistle
Post #21848 11th Jan 2010 1:41pm
K9F
Me too, but Fekete beat us to it allbeit in a more diplomatic manner! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #21850 11th Jan 2010 1:58pm
jamesbond007
Portugal 2009 Defender 110 Puma 2.4 XS DCPU Rimini Red
When I look at K9F's avatar, I know where the squeak squeak comes from... Boldly going nowhere
Discovery 3 after a Defender 110 Crew Cab TD4 and a 1964 SIIA 88 Regular.
Post #21859 11th Jan 2010 2:52pm
