![]() | Home > Td5 > Cruise control with an overdrive. |
df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 ![]() |
Ill give this a bash, not very good at explaining things.
For the general td5 NNN cruise control wiring I followed http://www.landyonline.co.za/landyforum/vi...amp;t=3230 Fairly good description. Now for those with the overdrive/disco transfer gears, my understanding is that it won't work because the pulse rate from the speedo entering the ecu, when compared with the engine revs lies outside of parameters set by landrover. So to cure this we have to reduce the pulse rate entering the ecu, but not the speedo on the dash. You need to locate the speedo wire, I found the following useful to itemise what each pin does. http://www.lro.com/forum3/viewtopic.php?f=44&t=59898 You now need a photo of the plug showing which pin is which. ![]() Click image to enlarge Not sure how clear the photo is but if you google td5 ecu plug diagram and click on images youll get it, this also gives a simple schematic of wiring up the cc. The Speedohealer looks like this; ![]() Click image to enlarge Basically you can alter the pulse rate as a percentage of that entering it. Iirc I reduced the pulse rate by 15% and it's working perfect 6 months or so now. The wiring diagram for the Speedohealer comes with, basic, snip the speedo wire enter the ecu, connect the Speedohealer in line and give it power from somewhere, I just took it from the fuse box. This doesn't effect the speed shown on the dash. I used an on-off switch and an electric window switch I picked up on eBay for operating the cc. Put these on the front of the cubby box. ![]() Click image to enlarge I probably left out bits, it's a while since I did it, any questions throw them up (and I'll ignore the hard ones ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Just found this on my computer
![]() So it's B13 that needs to be interrupted by the Speedohealer to have pulses within parameters accepted as normal by file in ecu. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
