Home > In Car Electronics > USB confusion
ZeDefender
USB confusion
Please can someone explain?
Just installed a 2.1A double USB power socket (posh one from BlueSea) and a cheaper 1A single one Smile
Both sockets work and charge my iPhone. Only the 2.1A BlueSea charges my iPad.
However, for some reason, only the 1A socket will charge my little Nokia phone. When I plug it into the BlueSea nothing happens - it doesn't make sense Confused
Ideas?
Matt Tell someone you love them today because life is short.
Post #216958 7th Mar 2013 4:51pm
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
USB stuff can be quite fickle - I know that your iPad will not charge on a supply that outputs more than 2 amps.
I suspect your Nokia will not charge on anything over a certain figure - to protect itself from frying. My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #216962 7th Mar 2013 4:57pm
^^^^ Sounds about right to me. Thumbs Up $W33T $0U7H3RN $UG4R
Post #216968 7th Mar 2013 5:04pm
TheWarden
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
A lot of devices won't work with more than 500mA - this is probably the case with the Nokia.
The iPad has a bigger battery and needs more juice to charge. It will charge off the 1A - it just won't indicates it's charging... give it a lot more time and it will fully charge.
Post #216969 7th Mar 2013 5:05pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
You can't output more current than is demanded.
The current quoted is the maximum current draw. What is supplied is dependant on the load.
Post #216988 7th Mar 2013 6:04pm
ZeDefender
That's what I thought - even though a power outlet can provide 2A maximum, a 500mA device shouldn't care (it won't draw more than 500mA and the outlet can't "push" more than is demanded). Unless for some weird reason the Nokia senses that more current is available (than it needs) and doesn't like it - but that doesn't make any sense Rolling Eyes
My big trouble is that the 1A socket is just a stop-gap, as a second BlueSea (f'ing expensive) will arrive soon from Blighty Thumbs Up
Thought I was doing well, but not being able to charge the Nokia is a totally unforeseen, ridiculous problem Big Cry Tell someone you love them today because life is short.
Post #216995 7th Mar 2013 6:24pm
VeeTee
Netherlands
Actually, Nokia thinks this does make sense Shocked
Some Nokia models are equipped with current and temperature sensor, and are charged with a fixed current at a higher voltage than USB, 6.1 V @ 890 mA.
Could be that the characteristics of your cheap (unregulated) 1A charger are just OK for Noka while the BlueSea does not fit because of fixed regulated current and/or voltage... Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #217018 7th Mar 2013 8:03pm
ZeDefender
Aha!
Many thanks Thumbs Up
Now what to do about it Confused Rolling Eyes Tell someone you love them today because life is short.
Post #217019 7th Mar 2013 8:07pm
VeeTee
Netherlands
If you have an inverter on board you could use the original Nokia 230V charger... Cheers, Vincent
MySite
Post #217024 7th Mar 2013 8:26pm
me@td5.org
Are you saying that the Nokia USB charger is expecting to see over voltage?
Post #217025 7th Mar 2013 8:31pm
ZeDefender
Thanks, but not quite the "streamlining" I was hoping for Laughing Tell someone you love them today because life is short.
Post #217026 7th Mar 2013 8:36pm
VeeTee
Netherlands
Modify an dumb charger to charge Nokia:
http://talk.maemo.org/showthread.php?t=38230 Cheers, Vincent
MySite
Post #217044 7th Mar 2013 9:30pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
And VeeTee wins the prize!
This is a simple case of voltage regulation. A lot of Nokias require a 5.1V supply. The BlueSea unit will almost certainly more accurately regulate the voltage to 5.0V exactly, and under all conditions, whereas your cheaper 1A unit is probably not as well toleranced and will allow the voltage to exceed this, probably reaching up to 5.2V or maybe slightly more, which is why it works with the Nokia.
You can prove this by Censored a standard PC USB cable and plugging one end into your USB socket, and the other end to your multimeter, then compare with the other socket. If you want to try this but are unsure, PM me and I'll take you through it.
Don't be mislead by the comments about devices being able to determine the current capability a particular outlet has. You can't change the law of physics. You could plug into a socket which could supply 100A. The device will only draw the current it needs, as long as the voltage is correct.
Pete
Post #217075 7th Mar 2013 11:15pm
ZeDefender
Another little project - many thanks Bow down
Matt
p.s. thanks too Pete (and all others) Thumbs Up Tell someone you love them today because life is short.
Post #217083 8th Mar 2013 7:12am
VeeTee
Netherlands
Thumbs Up Cheers, Vincent
MySite
Post #217145 8th Mar 2013 1:29pm
