Home > Td5 > Strange alarm issue
TD5_90
United Kingdom 1999 Defender 90 Td5 CSW Epsom Green
Strange alarm issue
Hi
When I switch my lights on the alarm siren sounds and the lights don't actually come on!
Still drivable, not immobiliser kicking in but the alarm.
99my Td5 and doesn't have central locking so to be honest I don't use the fob! Issue just kicked in today.
Any thoughts? Help!
Post #216670 6th Mar 2013 4:23pm
Sounds a bit random but maybe an earth fault? Darren
Post #216672 6th Mar 2013 4:31pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
I've had a good look through the wiring diagram and I can't see anything that could cause the, especially as your alarm is not activated (because you are not using the fob)
Check all of your fuses and links in both boxes, especially those related to the indicators and check all of the earths but I suspect you either have a battery problem or a problem with your 10AS unit.
Post #216703 6th Mar 2013 6:28pm
TD5_90
Thanks both. I will check tomorrow.
I have recently taken my tow bar off to refurb the cross member - this included disconnecting the tow electrics. Could this have caused any issue?
Thanks
Post #216717 6th Mar 2013 7:11pm
me@td5.org
Quite possibly.
This may help you investigate:
http://www.legionlandrover.com/manuales/el...(1999).pdf
Post #216722 6th Mar 2013 7:23pm
TD5_90
Thanks.
I appreciate your help. I will have a look tomorrow but then it will have to go to the local independent. . .
I will update with any resolution.
Post #216728 6th Mar 2013 7:38pm
TD5_90
Update: went into the independent and they traced a wiring fault.
Inside the N/S front wing the lighting and alarm sounder wires had chafed together and therefore current to the lights was sent to the alarm sounder.
All working fine now.
Thanks for your input.
Post #217356 9th Mar 2013 7:45am
