Home > Technical > Bolt specification?...Stainless?.or not?
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I currently have the tow bar off my Puma.
The bolts are rust coated. (Nothin new there!)
I thought maybe I could re-assemble using stainless bolts.
Do I need to ensure the bolts are a certain tensile spec?
How do I know?
Clemmo Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion 17k miles
Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun
Post #215946 3rd Mar 2013 10:18pm
Re: Bolt specification?
How do I know?
Clemmo
Yes, but I can't remember what exactly now. Confused IIRC it's stamped on the head of the bolts. I too would be interested to know what could be used safely and legally.
Off Topic But I'd also like to know if a spreader plate is really required required or not too Question $W33T $0U7H3RN $UG4R
Post #215947 3rd Mar 2013 10:22pm
x-isle
I think a min of 8.8 will do you. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #215953 3rd Mar 2013 10:40pm
smb
How do I know?
Clemmo
Always make sure they are graded 8.8. There will be a lot of Dynamic forces applied to the system(nut, bolt & thread) whether you are accelerating, decelerating, bumps, etc... and that is just in normal driving. You then need to consider the forces applied in an emergency.
8.8 is not that much more expensive as long as you don't go to Landrover, Halfords, etc...
Post #215954 3rd Mar 2013 10:40pm
That's the spec I was trying to think of. I think that's what mine have on at the moment. $W33T $0U7H3RN $UG4R
Post #215957 3rd Mar 2013 10:48pm
Clemmo
So is that the number stamped on the head of the bolt?
Thumbs Up
Post #215960 3rd Mar 2013 10:52pm
Laurie
Stainless steel bolts fatigue more easily than HTS bolts.
Better to stick with HTS.
Post #215962 3rd Mar 2013 11:02pm
leeds
Yes.
Some details here http://www.hi-tensilebolt.com.au/Head%20Markings.html
Please note in general terms stainless bolts do not have the same tensile strength as high tensile bolts, they are weaker.
General rule of thumb you do not use stainless in importan high strength areas so not on tow ball.
Common available stainless bolts are A2 70 (700 MPa) whereas standard high tensile bolts are 8.8 or 800 MPa.
Brendan
Post #215963 3rd Mar 2013 11:08pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
As per Brendan's link, you can get A4-80 (800MPa) which is broadly similar in strength to 8.8 high tensile if you want to go stainless, and these were what I used for some of the more 'cosmetic' fixings for my NAS step.
For everything which is subject to shock or is more heavily loaded, as x-isle said go for a minimum of 8.8 high tensile and not stainless, such as the tow ball. I used 12.9 for all of mine including the ball just for peace of mind, and they weren't much more expensive than 8.8 either.
You then just need to make sure that you torque them up (preload) them properly, and the job's a good un.
Pete
Post #216000 4th Mar 2013 8:37am
If your vehicle is "M" series Euro-type approved (ie not commercial) then the the towing system must also be type approved and this will include fasteners. Replacing any fasteners other than with like-for-like will therefore technically be illegal.
Personally I don't see any point in not using grade 8.8 BZP or ZPP fasteners; these will match the original and will both strong and durable. There are several issues apart from strength which can affect stainless fasteners (ask anyone who's tried to dismantle a Patriot rack after a few years)!
A normal off-the-shelf "high tensile" fastener will (unless you specifically order/ask for something else) be grade 8.8 unless is it a socket-head capscrew or bolt (hex, spline, or Torx socket) in which case by default it will be grade 12.9, which is in effect the next grade up from 8.8.
Post #216020 4th Mar 2013 10:03am
Clemmo
Can you please explain?
Post #216022 4th Mar 2013 10:22am
leeds
A2 stainless is rust resistant in fresh water and is most commonly available stainless bolt.
A4 stainless is rust resistant in salt water marine and more chemical environments.
Note have said rust resistant rather then rust proof.
For specialised environments yes it is possible to get special exotic grades of stainless bolts but not relevant here.
It is possible for stainless to cold weld itself to a bolt IF you have not used some paste. If it cold welds itself then you may well shear the bolt before undoing the nut. OK I do not fully understand the process of cold welding
Quote:
Galling (cold welding) is a form of severe adhesive wear. The mechanism is briefly described. Soft very ductile austenitic stainless steel types tend to gall or seize where high stresses and poor lubrication are present.
Have a read HERE
This is one of the reason Nakatanenga/Entreq has a tube of paste with their stainless kits.
Brendan
Post #216025 4th Mar 2013 10:32am
I don't understand cold welding either but I've managed to do it Embarassed
Post #216027 4th Mar 2013 10:34am
Exactly as Brendan has said! Throw in a large number of countersunk hex-socket-head capscrews and just about every fastener will end up being destroyed if you have to dismantle the rack.
You will probably have gathered that I am not personally a fan of stainless fasteners for everyday use, although in the right environment and circumstances and used correctly they are great.
Post #216029 4th Mar 2013 10:35am
BigMike
Just replace them like for like then spray them with acf50 and every 6 months. job done.
Post #216040 4th Mar 2013 11:25am
