Home > Maintenance & Modifications > RDX Lights
Mr Baldylocks
United Kingdom 2002 Defender 90 Td5 CSW Bonatti Grey
RDX Lights
Evening Guys and Girls
Well I've just fitted the first part of my lights and I'm bloomin frozen. Looks really good though and great value for money, I'll finish the indicators tomorrow and fit the side power vent. Now time to break open the Thatchers and start the chicken casserole.
Any advice on sound deadening and insulation? Is there anyway to warm the cabin up quicker in the Old Girl? I'm in and out of 2.2s all day long and they definitely warm up quicker.
Cheers Guys Thumbs Up Life is one big adventure, that's why we have the vehicle for the journey.
Post #215628 2nd Mar 2013 8:44pm
Re: RDX Lights
There are alternatives, but a search for 'Dynamat' will tell you all you need to know. Darren
Post #215635 2nd Mar 2013 8:53pm
bob neville
Dynamat for insulation and soundproofing Thumbs Up
Group buy here http://defender2.net/forum/topic17772.html
Simple check to make on the heater that can make a lot of difference.
Set the hot/cold lever to full heat.
Open the bonnet and check the arm on the heater box that the cable is attached to. It should be FULLY over to the right when looking from the front. See if you can move the lever any further to the right by hand. If you can then adjust the cable so the lever is fully over.
You may only get a few extra mm's of adjustment but it really makes a difference. I had to wait ages for the TD5's heater to give warmth into the cabin. I did this check and had about another 3mm of travel on the lever.
Adjusted the cable and now the heater blows warm in about 5 minutes and hot in about 10.
If you have the dash top off also make sure all the hoses are connected fully, they have a habit of working lose over the years.
2013 Defender 90 CSW - sold
Post #215697 3rd Mar 2013 9:42am
barbel jim
Dynamat all the way Very Happy Very Happy Very Happy Easy to apply and waterproof. Think SGH has a group buy somewhere on the Forum. Open cell such as noisekiller also works, but will attract and hold water- thus rendering it useless. My 90 HT used about £450( 120 sq/ft iirc) did it all bar the roof and worth every penny. Thumbs Up There are some cheaper alternatives, such as silentcoat, rattle trap etc which I have not used, but are based on the same principle. Dynamat has been around for years and I cannot fault it, hence the reason to pay a little more and gain peace of mind. Thumbs Up
Post #215732 3rd Mar 2013 11:53am
mk1collector
Dynamat is not an insulation though so your best to dynamat and then stick closed cell foam over the top.
Post #215737 3rd Mar 2013 12:46pm
barbel jim
Agreed, but as a added bonus it dose aid retaining the warmth. One of the benefits of the aluminium face. Mine is noticeably warmer Thumbs Up
I put closed cell on the sides, any where above the floor is good but having read others experiences, decided against anywhere that would get wet !!
Post #215789 3rd Mar 2013 3:05pm
mk1collector
It doesn't matter if closed cell foam gets wet as it doesn't retain water.
Post #215817 3rd Mar 2013 4:37pm
barbel jim
sorry I meant open cell Embarassed
Post #215862 3rd Mar 2013 6:42pm
Mr Baldylocks
Brilliant, thanks for your help guys, I'm off tomorrow Bob so I'll try your method on the cable. I thought that Dynamat was the way to go so a bit on saving to do then that could be the next job. Where's the best place to get seat risers from?
Cheers Life is one big adventure, that's why we have the vehicle for the journey.
Post #215881 3rd Mar 2013 7:28pm
bob neville
Probably Mud Rails direct from Mud unless Leeds (Brandan) does them, drop him a PM.
The Exmoor ones are expensive and a pain in the proverbial Laughing
Post #215911 3rd Mar 2013 8:19pm
leeds
Yes we have the Mud seat rails in stock Thumbs Up
Brendan
Post #215914 3rd Mar 2013 8:24pm
