Home > Technical > How to fit xs side step/bars instructions?
Page 2 of 2 <12
Porny
Site Sponsor
Defender-Stu wrote:
would these be the same as what would use on the front mounting points of the steering guard that goes through the chassis?
The steering guard uses M10 or M12....
If you can wait, I can bring my rivnut gun to the rolling road day, is only 2 mins to fit a pair of rivnuts...
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #212343 19th Feb 2013 11:08am
Laurie
My nearside suffered a bang when dropping off a rock about 4 years ago.
It's now got a three finger size hole rusted through at the rear mounting point.
Seems they need repainting rapidly if you do bang them on something.
Post #212345 19th Feb 2013 11:16am
Defender-Stu
Ian
Hi Ian,
That would be great mate if you could help Thumbs Up i will order the supports and i have a load of M8 bolts and washers etc so will bring some with me, would i need to get anything else or will the supports come with new bolts etc?
Stu
Post #212352 19th Feb 2013 11:58am
LinDens90XS
2003 Defender 90 Td5 XS CSW Bonatti Grey
If I may make a suggestion, take off the bungs on the ends of the main tube and wax oil inside and every time you power wash take the bung off again to drain as water makes its way inside through where the checker plate is riveted. Just replacing mine next week as mine rusted through from inside. Hope that helps.
Regards Dennis.
Post #215440 1st Mar 2013 11:13pm
LinDens90XS
Regards Dennis.
Post #215441 1st Mar 2013 11:14pm
LinDens90XS
Just removed rusty steps and my apologies, water not entering where checker plate riveted but at the top of the tubes where fixed, they are open so power wash and dunking in muddy water just filled it up and nowhere to go but rust.
Regards Dennis.
Post #215935 3rd Mar 2013 9:27pm
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
Going to revive this thread in the hope that someone would be kind enough to measure their support bars so that I can make some Thumbs Up
Post #516825 22nd Mar 2016 7:01pm
ROB1N
2006 Defender 110 Td5 DCPU Java Black
f15hie wrote:
Not a great picture but you get the idea
Shows the bars fitted
A few posts to go
Hi i have a set of these bars but no instructions does anybody have some or at least a pic of what they attach too cheers Rob.
Post #720297 29th Jul 2018 6:14pm
Stu_XS
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
It’s quite obvious when you offer them up under the truck Robin. Stu...
2013 Aintree Green 90 XS SW 2.2 Puma
Post #720319 29th Jul 2018 7:56pm
ROB1N
i did but there appears to be something that is missing ?? just a photo of where they mount before i amke some mods
Post #720539 30th Jul 2018 7:41pm
Stu_XS
They look complete in the pictures.
The front bolts along the inner sill, the stay bar to the chassis and then the rear bolts in to two existing bolts and finally there is another bolt hole just below that. Stu...
Post #720543 30th Jul 2018 7:50pm
ROB1N
Sorted had to make some support bars and sort out some fixings etc
Post #720735 31st Jul 2018 7:29pm
Page 2 of 2 <12
