Home > Td5 > Bulb replacement on land rover fitted spotlamps on A softbar |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5664 |
Think there is a small screw on the very bottom of the bowl. Then they may need a bit of twisting, prying, to separate the two parts at the bottom and then unhook the tops.
Andy |
26th Feb 2013 8:21pm |
TooTall Member Since: 10 Jul 2012 Location: Fens Posts: 504 |
^^ What he said ^^
I had the same problem but can I also suggest that before you rebuild the spots; you weatherproof them with some black B&Q bathroom silicon sealant... "Ease your worries, Clear-up your woes, Go into your garage & put stuff into rows." |
26th Feb 2013 9:13pm |
Pete Kettell Member Since: 17 Dec 2012 Location: Devon Posts: 11 |
Thanks Landy Andy, but there is no small screw on the bottom. It appears that they only way to get at the back screws is to undo the clamps and rotate them taking them out of alignment. A small problem, but if I didnt have to use that option I wouldn't . Maybe thats the way to go if no better options appear. Weatherproofing them seems a good idea Too tall. Thanks for your input Currently on my fifth Defender. Had bespoke soft top and a 300TDI I bought twice and two TD5's. Currently driving the best second hand 2004 TD5 in the country
27th Feb 2013 11:33am |
You might be best putting up a pic of the lights so we can give you a definitive answer.
27th Feb 2013 12:04pm |
Blimey, I've just spent ages trying to work out how to post a pic on the Forum. I think the time would be better spent on working out how to remove the headlamp bulbs. LOL Currently on my fifth Defender. Had bespoke soft top and a 300TDI I bought twice and two TD5's. Currently driving the best second hand 2004 TD5 in the country
27th Feb 2013 2:33pm |
TR51 Member Since: 17 Apr 2012 Location: Dorset UK Posts: 333 |
Pete this may help...
http://www.defender2.net/forum/topic123.ht...load+photo |
27th Feb 2013 2:38pm |
Thanks for the tip. I have now successfully loaded a pic of the lights into my gallery, but I dont know how any of you would view it, but its there if you know how. Thanks everyone Currently on my fifth Defender. Had bespoke soft top and a 300TDI I bought twice and two TD5's. Currently driving the best second hand 2004 TD5 in the country
27th Feb 2013 4:43pm |
Jes its easy, just click on gallery! Currently on my fifth Defender. Had bespoke soft top and a 300TDI I bought twice and two TD5's. Currently driving the best second hand 2004 TD5 in the country
27th Feb 2013 4:44pm |
Click image to enlarge There you go, sorry they're not the style I know how to strip down... |
27th Feb 2013 6:31pm |
Ok, it will be easiest to unbolt the light off the a bar at the top as there are three posidrive screws to undo on the back of the light then the bulb just unclips out.
Hope this helps Ray |
27th Feb 2013 7:06pm |
You may be able to loosen the bolt that holds the light on the a bar and just spin the light around instead of taking it off completely but be careful you don't break the wires
27th Feb 2013 7:09pm |
Thanks Guys, had to swing them round in the end. Currently on my fifth Defender. Had bespoke soft top and a 300TDI I bought twice and two TD5's. Currently driving the best second hand 2004 TD5 in the country
4th Mar 2013 2:00pm |
