Home > My Defender > Time warp 90 |
JOSNOS Member Since: 06 Apr 2012 Location: Bucks Posts: 154 |
Took the flywheel cover off the 200 tdi and a spare 2.5 diesel today whilst taking the cover off the 200tdi found out the gasket has broken so need to buy one and scrapping it off was a . but gradually getting there
200tdi engine complete Click image to enlarge Got clutch off and unbolted the flywheel but it was stuck on there tight Click image to enlarge got the flywheel cover off Click image to enlarge the gasket was hard to scrap off Click image to enlarge the remains of the gasket Click image to enlarge trying to take the clutch off the 2.5 Click image to enlarge couldnt get the impact driver on it. had to hammer a socket on the nuts Click image to enlarge nearly there Click image to enlarge took all the parts back home from my dads work in my fiesta Click image to enlarge such a good piece of kit Click image to enlarge bolts in labeled bags for each step Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 2003 TD5 90 |
24th Dec 2012 7:46pm |
Found some photos of removing the engine out of the discovery with help with my dads friend nicknamed the mad professor
Disco stored in the back garden for a year or two Click image to enlarge 200tdi looking a dirty but nothing that the steam cleaner Click image to enlarge the mad prof getting to work Click image to enlarge Click image to enlarge It out didnt take that long Click image to enlarge Got a good engine crane Click image to enlarge done a bit more on the engine today took the water pump, crankshaft pulley bolt and more just to get the tiiming cover off. snapped a few bolts in the process time to start Click image to enlarge water pump off probably buy a new one only 20 years old Click image to enlarge first snapped bolt on whilst taking off the water pump off due to the gasket failed and the bolt rusted Click image to enlarge the crankshaft pulley bolt wouldnt come off so applied a bit of heat to it Click image to enlarge Click image to enlarge finally got the timing cover off after stud extraction of the snapped bolts Click image to enlarge took the timing gears out Click image to enlarge its always good to have the right tools for the job for the stud extraction Click image to enlarge one of the studs i took out and the crankshaft phosphor bronze spigot bush Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
26th Dec 2012 8:54pm |
Finally stripped down the engine ready for painting today, starting to look good
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 2003 TD5 90 |
27th Dec 2012 6:01pm |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 |
its nice to see someone doing the rebuild for themselves for a change 2004 TD5 Defender 90 xs station wagon
27th Dec 2012 7:16pm |
Cheers mate 2003 TD5 90 |
27th Dec 2012 7:17pm |
lucky I'm only doing the engine so it pretty straight forward but the next project is my V8 90 which is going to be fun 2003 TD5 90 |
27th Dec 2012 7:29pm |
Just so you dont feel left out 2004 TD5 Defender 90 xs station wagon |
27th Dec 2012 7:49pm |
Painted the block today in fordson blue
28th Dec 2012 6:17pm |
I've been busy with my engine. polished up the vacuum pump and oil filter housing also got a new fuel pump and fitted them to the engine.
bit blurry Click image to enlarge Bought a another 200 tdi engine because it had the zeus timing gears on it so i took them apart. but need to change a plug on my engine for the zeus gears to let the oil in the timing case. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Polish up the front timing case still need to the rear one though. Click image to enlarge Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 2003 TD5 90 |
24th Feb 2013 6:57pm |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 |
Looks good, (love blue block), but are you sure about the Zeus gears? I find the noise really annoying (ironic slightly being a Land Rover!) and really don't see the benefit over a correctly changed belt.
Just my thoughts though! |
24th Feb 2013 7:08pm |
Well my dad swears by them as they are more economically as the keep the timing more accurate and i dont mind the noise as i going to take the roof off in the summer 2003 TD5 90
24th Feb 2013 7:54pm |
Rob Member Since: 04 Sep 2012 Location: Brownhills Posts: 40 |
I'm sorry but I DON'T agree with you sticking a TDI in, you have ruined a very original 90 I go round the classic car shows and land rover shows and I've yet to seen an ORIGINAL 90 or 110 with its ORIGINAL engine in!!!!!
26th Feb 2013 5:34pm |
And I completely disagree with that!!
Yes its a nice early 90, yes its getting unusual with its original engine. Its not unique, its not special, its not particually rare. Its his 90, nothing is reversable if he wants to change it back (I hope he doesnt, he's doing a very nice job on it!) |
26th Feb 2013 5:57pm |
foxkilla Member Since: 01 May 2009 Location: J23 M1 Posts: 156 |
+1
26th Feb 2013 6:19pm |
