Home > Technical > Hazard light switch - illuminated or not?
Page 2 of 2 <12
ericvv
Post #213808 24th Feb 2013 1:41pm
superspoons
England 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Cheers Ericvv Thumbs Up Cheers,
Superspoons
Post #213831 24th Feb 2013 3:39pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Well, changed the Hazard switch bulb today so now I have an illuminated switch. Took 10 minutes in total.
Ericvv, you stated that when the Hazards are on you get the 2 green indicator arrows. I get that + a red warning triangle on the dash. Do you get that also? Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #283522 19th Nov 2013 6:44pm
miket
Mine used to light up until the dealers took the dash out to repair corrosion around the windscreen. Now it doesn't light up. And my right hand indicators sometimes stay on, even when everything is switched off. And the heater controls don't work correctly.
Post #283540 19th Nov 2013 7:38pm
ericvv
Correct, same here. The only thing that does not happen is the red light in the distress command button flashing when in the on position. Which is different than most other cars.... But that is what makes it a Defender,yes? Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #284025 21st Nov 2013 3:29pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Mine works exactly as it should:
Switch only illuminates with lights on; when activated both indicator warning lamps flash in the display panel, along with the triangular hazard warning lamp in the display panel - the switch itself stays constantly lit. AND the trailer direction indicator warning lamp flashes, which it doesn’t do if a trailer bulb has blown.
Peter
Post #284058 21st Nov 2013 4:55pm
PaulMc
For anyone who needs an STC1205 bulb and holder for their hazard warning lights switch, you may be interested in this eBay listing -
BRAND NEW RANGE ROVER P38 HAZARD WARNING LIGHT SWITCH - AMR2691 - LAND ROVER
These switches are £1.00 each + £0.71 postage (to the UK)
Each switch has 2 x STC1205 bulbs in it Thumbs Up
If you buy an STC1205 bulb and holder from a dealer, they're £3.40 each (incl. VAT)
. Paul.
Post #286134 28th Nov 2013 9:57pm
WelshGas
Too true, Paul. Just received my switch £1.71 in total. Bulbs added to my spares collection. Told my local Indy - he is ordering some. Whistle LANDYWATCH
Post #287290 3rd Dec 2013 11:48am
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
bulb is in red housing in bottom of switch -
Post #289957 12th Dec 2013 9:28pm
ericvv
Mr James, were you able to take that switch out of the dash without removing the dash, so without accessing it via the rear? How does that work? I believe my dealer had to release the center dash to get to the back of the switch when replacing the bulb.
Tks, Eric You never actually own a Defender. You merely look after it for the next generation.
Post #290071 13th Dec 2013 11:25am
WelshGas
You do not have to remove the dash, just the radio so that you can put your hand in and up behind the switch and push and wiggle it forward. You do not even have to disconnect the radio to get access. Takes less than 5 minutes if you have the correct tool to remove the radio. I have a 3rd party radio with its own fixing cage and I was still able to do it without removing the cage. If you still have an original LR radio then it is even easier as there is no fixing cage, well there wasn't on my 2010 MY XS. Thumbs Up LANDYWATCH
Post #290101 13th Dec 2013 1:53pm
MR_JAMES
Very easy. I removed the radio with some cheap release keys off ebay that cost £1.99; (left it connected) then pushed the switch out from the rear. easy peasy.
Post #290255 14th Dec 2013 1:17pm
Page 2 of 2 <12
