Home > Maintenance & Modifications > Winches
Forest of Dean 90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Winches
What Winches (and Battery) do people recommend for light recovery use (not full on mud pulling) and has anyone looked at the "Winch in a Box" which goes on your Tow Bar so its not permanently attached so reduces the light finger brigades chances of pinching it, also is it legal to have a Tow Bar fitted on the front of a vehicle?
Thanks in advance for any suggestions..[/i]
Post #21149 3rd Jan 2010 12:30pm
RLD
i am sure you could put a tow bar any where there are plenty of threads on here about winches RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #21150 3rd Jan 2010 1:07pm
RLD
Buellbeast on here has a front winch and bumper for sale at a good price look under For Sale RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #21151 3rd Jan 2010 1:15pm
mse
Nothing wrong with a towbar anywhere - put a reciever hitch front and back is good.
The only issue with some of these kit winches (winch in a bag or winch in a box) is the rating of them.
Warn do a good removable tray that accepts certain winches and locates in the reciever hitch which can thus go front and back - i think they used this in the freelander on the last camel trophy. Mike
Post #21155 3rd Jan 2010 3:17pm
AndrewS
I think AlexE has a bumper tow ball winch mount for sale. I will give him a prod Thumbs Up
Post #21185 4th Jan 2010 9:56am
Alex e
England 2006 Defender 110 Td5 DCPU Zambezi Silver
Thumbs Up yep i have a winch tray which is designed to sit on a tow ball, have never fitted it as didn't have time to wire the winch up prior to the tunisia trip, and to be fair i think it is a great bit of kit. it's one of the only things i have left as i've sold up, and was just hinking when i was going to get around to selling it.
i'll see if i can get a pic of it for ya if you're interested? Whistle
Post #21187 4th Jan 2010 10:02am
AndrewS
I'm on the case Thumbs Up Did it have an Anderson connector with it as well Question
Post #21188 4th Jan 2010 10:07am
AndrewS
Post #21190 4th Jan 2010 10:14am
Alex e
it does now! Wink
yeah i bought all the cables and anderson connectors to do it. Bow down
Post #21192 4th Jan 2010 10:43am
TJ101
As for the winch
By far the best value is the TDS for David Bowyer @ Goodwinch http://www.dborc.co.uk/goodwinch/
Well impressed
Just fitted one as a centre winch on the challenge truck,, Seen them pulling under water, very popular and successful as a rear winch on comp vehicles, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #21241 4th Jan 2010 10:26pm
Ryders arnt to bad either the 12000lbs XP lookalike worked for me
Post #21249 5th Jan 2010 6:23am
mse
Is anyone a little concerned at the 3t rating of the towbar ball?
I remember someone on the disco owners club (new disco at the time) have a winch on the std towball and damaged it winching at not even full pull! Mike
Post #21250 5th Jan 2010 7:55am
Glynparry25
There is no problem doing a towball winch mount but rember that a tow ball is designed to have all its stress straight forward or back, so if you put 2-3 ton pull (easy to do when bogged in) at a 45 degree angle (because there will be minimal tow points directly behind) and the tow ball mount will be well overstressed. Also, where abouts would you mount the front tow ball? The bumper will bend with about 1/4 ton force.
As advised above- if going down this route I would go for a 3" reciver mount
Glyn
Post #21268 5th Jan 2010 11:03am
jst
TDS Goldfish from Bowyer gets my vote, bloody good value for money, work with synthetic rope (External brake) and pull like anything. We have run one for 2 years on the rear of our challenge truck and its been superb.
Mounting wise i ran a demountable cradle system for a std size (8000lb) winch that used a cl2 receiver hitch front and rear. worked well for what i wanted it for at the time.
In fact its still in the garage somewhere, complete and is for sale. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #21382 6th Jan 2010 9:57am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Surely it's all about budget, I got a C9500TDsi Champion with full fitting kit and bumper for under �500 notes. This will work fine, not the fastest winch but very well built and reliable, this leaves alot of money left over for other kit. Now competition winching and daily heavy use is a different story. Most people buy a winch and use it half a dozen times a year. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #21384 6th Jan 2010 10:25am
