![]() | Home > Puma (Tdci) > Two stroke in fuel |
Ric Member Since: 03 Nov 2012 Location: South Yorkshire Posts: 209 ![]() ![]() ![]() |
Who uses two stroke in their fuel,
If so, then what spec and ratio? Thanks its only a car! |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
Use the search feature, been done to death on here
For example....
http://www.defender2.net/forum/topic18309....two+stroke http://www.defender2.net/forum/topic15273....two+stroke http://www.defender2.net/forum/topic9189.h...two+stroke http://www.defender2.net/forum/topic1708.h...two+stroke ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Just buy premium quality diesel, do not need that 2SO stuff then
![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
Oh yes you do !
None defender now,
Would it be worth adding redex diesel system cleaner along with the correct 2SO its only a car! |
I'm not sure thats a good idea. I tried mixing them to save adding two different substances every time I filled up. There soon appeared a gungy sediment at the bottom of the bottle and I thought it would not be good for the fuel filter or anything else so now I just use the 2SO on its own
Toplink Member Since: 05 Dec 2010 Location: Somerset Posts: 159 ![]() ![]() |
Every time I put 2so my mpg goes down by 10% ish
![]() 2007 Defender HTop. 1952 Series One 80" 1977 Muir-Hill 111. 2014 Triumph Tiger800xc 1999 Discovery 2 td5 1982 Ransomes TSR300D. 2002 Yamaha XT600e. 2010 Freelander2 (the wifes) 2008 John Deere X140 |
