![]() | Home > Maintenance & Modifications > lsd or locker in frotn axle |
I was hoping some one would come on with some experience of the Detroit Truetrac, cos thats what i'm looking at rather than the full ARB, Sonic fitted the ARB so he can tell us about that unless he's still stuck in a sand dune
![]() 110 HCPU Tipper |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 ![]() ![]() ![]() |
I was in the same dilemma. TTrac would be to upgrade somehow the traction performance. An ARB would give you full traction but you would have issues when turning. Depends what sort of difficulties you`ll face. I have 285 tires so I think I`m on the limit for a Ttrac. I do have a rear ARB on my 110".
I imagine a muddy steep curve: I guess I canīt use the rear arb, neither a front one. The choice would be a ttrac unit I guess. For crawling and that sort of fun an ARB would be my choice. Puma 110" SW ............................................................. Earth first. Other planets later |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 ![]() ![]() ![]() |
Most people i have met (unless really going hard core off roading/challenges) say avoid one on the front as they give very little benefit 90% of the time and the steering is an issue.
LSD would be the way i would go if i was going that way with a full ARB/KAM on the back. Mike |
In my 1997 Camel Discovery I had a Detriot Locker in the rear axle and a True Trac in the front axle. I really loved that combination I will transfer them to my 90 when it's ready.
Because the detriot drives the slowest side, It pushes the car to the outside off a roundabout, you can steer against that no problem but if you come off the throttle suddenly the car will want to go to the inside off the roundabout. The first few times it can be scary but you get used to it and if you come off the throttle a little slower there is no problem. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
the problem i face is that eventually it will be a challenge truck and on road i dont think an lsd in the front is a good idea at least with a locker its either on or off but god knows how many times strong than a standard diff 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
A LSD (limited slip differential) is OK in the front axle as it doesn't really lock up. Basicly there are 2 types LSD's one with friction plates and the other with gears. Both create resistance when there is a torque input from the engine and a speed difference from the wheels. If you floor it while in a corner you might feel that it want to go more straight then without a LSD but I don't think that would be much.
You do not want an automatic LOCKER in the front axle. As it will put all torque to the front axle to the slower turning wheel that happens to be on the inside and wants to go straight. A more expensive switchable locker can be put in the front axle. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
thats what i am going to do arb air locker
uilt with 4pin diff iside any way and super duper strong cheers steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
Out the Dunes now ![]() ![]() ![]() |
The detriot locker is also locked when needed and 'unlockes' the wheel that doesn't need torque when cornering. The main advantage off the ARB is in my eyes that you can unlock it.
![]() You might want to have it unlocked on a sideslope. On a sideslope the upper tyre carries less weight and if forward traction is needed it will start spinning first. With a locked axle both wheels will start spinning and you might start sliding sideways downhill. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
