Home > Technical > Does a broken clutch suddenly fix itself?????
discocuzzy
Hunters of Guildford seem to think so!!!... Censored , was recovered in on Saturday they seem to think its ok now Shocked
The clutch biting point is now in the carpet, litterally lift your foot off the floor 5mm and its back in, struggling to get it into 2nd, fluid levels are fine and there are no leaks, any suggestions?, is there a adjuster anywhere? You cannot teach stupid people to do clever things
Post #21277 5th Jan 2010 12:23pm
AndrewS
One of the coil springs in the clutch plate may have become dislodged and has trapped its self in the lever mechanism. Does is make a clunk clunk clunk noise when you turn the vehicle off.
Random (ie not Defender) Clutch Plate with 6 coil springs these become week and fall out in the Defender Clutch.
Post #21290 5th Jan 2010 3:56pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
Re: Does a broken clutch suddenly fix itself?????
Mine did (the pedal returned to normal) - though the dealers did something to it anyway (or at least say they did) - see my post on your other thread.
Post #21300 5th Jan 2010 4:52pm
discocuzzy
Just picked it up from the dealer....all back to normal and they havent done any work on it.....very strange, ill keep an eye and ear on any strange noises. You cannot teach stupid people to do clever things
Post #21310 5th Jan 2010 5:58pm
Pob
United Kingdom 2008 Defender 110 Puma 2.4 HT Rimini Red
Spring now fell out altogether then now I bet Shocked 110 Hard top
Post #21323 5th Jan 2010 6:27pm
AndrewS
Ask them for a warranty print out
Post #21324 5th Jan 2010 6:31pm
T1G UP
that'll be the dual mass flywheel springs falling out, getting stuck then breaking up and freeing off for a while.
it'll do it again, as long as you've got the symptons logged
Post #21343 5th Jan 2010 8:50pm
AndrewS
I doubt that as it doesn't have one.
Post #21359 5th Jan 2010 9:54pm
