![]() | Home > Puma (Tdci) > LED Exterior Light Upgtade Problems |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2237 ![]() ![]() |
2012 110 XS 2.2 . Information and help for anyone who is about to change to LED indicators and stop - tail lamps . Yesterday I mounted my new 4 inch LED's . The same diameter as the rear fog and reverse lights . Holes drilled and mounted I proceeded to wiring . Red stop tail are straight forward and no problems and look great , however indicators caused an issue . Clearly they have to be fitted with resistors to slow the flash to normal speed but it's the resistor that's the issue . I fitted the correctly supplied resistor for the indicators but they still flashed fast , the resistor was still not pulling enough juice to slow the indicator to normal flash . The resistors are 33 Ohmmes and that's not enough pull , You need 10 - 15 Ohmmes resistor to get to flash at correct speed . Even my LED supplier didn't know this , apparently they work on earlier defenders so I'm guessing there a different wiring system on newer 2012 + models . Now they work perfect .
Mobile Centre supply a replacement flasher unit for LEDs that does away with resistors
Would I be correct to say that there is no flasher unit in this new year model ? Only because my LED specialist tells me that it is an electronic control unit used ? I'm no sparky .
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
What lights have you gone for ![]() ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
There is a flasher relay, there is no difference between the 2013 Puma and older Pumas.
Take a look at my website under LED lights to see a picture of the relay location. Replacement relay is plug and play, no procedures or twiddly bits |
That all seems abit technical mate ? Just to wire an indicator . My LED's are not the LR jobs . They are 50 led's 4 inch used on lorry's . Very nice and bright to Killer 90
its very simple mate really ![]() ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Thanks for the positive info and help .
