![]() | Home > Technical > Sikaflex 291 as a gasket sealant |
I'll give a
![]() ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5938 ![]() ![]() ![]() |
Cheers. Its getting annoying! 1999 Defender TD5 110
Whilst Sikaflex 291i is brilliant stuff it can only be used in temperatures of -40 to +90 on the rocker cover I would use Holdtite RTV853. Better than Sikaflex in a hot oily environment and used prolifically in the marine engineering world.
http://www.multibondsolutions.co.uk/index....gory_id=10 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Cheers K9F. If its good for Marine environment and upto 270 deg'c then it could be worth a dabble.
Maybe that's were I am going wrong and the Hermattie blue/red is breaking down with the heat? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 ![]() ![]() ![]() |
Have you checked if the head is warped or twisted. If it keeps blowing gaskets it sounds like something isn't right..?
Cheers Simon |
I hope its not warped or twisted as it had a new head about 3 years ago. 1999 Defender TD5 110
Might be worth putting it on a flatbed to check next time you take it off..
I wouldn't fret about a warped head just yet. Degrease as much of the rocker cover gasket surface as possible/practical. Try the Holdtite as it is 'fit for purpose' and a high grade and effective sealant and I reckon you'll have no further worries.
![]() Treat every day as if it is your last....one day you will be right!! |
Its not the head I am taking off! But worth checking the flatness of the rocker. 1999 Defender TD5 110
Use permatex aviation number 3 or loctite 515
df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 ![]() |
I'd imagine most of the products mentioned will do the job just fine.
I use Wurth products for various jobs and find them very good quality. |
