Home > Off Topic > The demise of the British Empire.... |
The Germans are coming
http://www.independent.co.uk/news/uk/home-...98723.html I guess it was found impossible to install on a Defender a system which automatically closes the windows and fresh air vents and engages the central locking system, while an oxygen supply provides breathable air. And also no solution to add to the Defender anti-terrorist devices such as a remote ignition which enables the engine to be started from 150 yards if it is suspected that explosives have been hooked to the starter system. And worst of all LR as a Defender option do not offer an “anti-kidnap” remote locking mechanism that allows the rear door to be locked and unlocked remotely by the police, making it impossible for Charles and Camilla to be trapped inside. Actually some of the above seem to come standard with some of our Defenders if I read thru the threads on Def2.net You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
20th Feb 2013 4:22pm |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 |
perhaps it should be fitted with a 2 way radio to the met traffic department to ensure they don't end up needing all the gadgets in the first place!
didn't barracks beast get caught on a ramp or security bollard? |
20th Feb 2013 4:54pm |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 |
I like the way it
automatically distinguishes fires under the chassis and engine bay. Probably because its posh. DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
20th Feb 2013 5:01pm |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
"distinguishes fires" that's a new way to use that word. Perhaps it only puts out special ones, not the mundane like I have.
Merlin |
20th Feb 2013 8:58pm |
