Home > Maintenance & Modifications > Steering wheels topic.......again!!
Page 2 of 2 <12
geobloke
Go Beyond wrote:
No, read my post again.
The 36 spline XS wheel (Only the XS wheel not the standard wheel) is the older one Thumbs Up
And yet my 2002 110 is not and XS and has a 36 spline wheel... LR steering wheels are a crazy crazy topic...
Post #212658 20th Feb 2013 4:06pm
36 spline columns were used in Defenders that were not Poverty spec, I presume yours is a CSW / County ?
My quote is taken out of context / misleading, sorry - in essence the spline count on the column is entirely down to the spec level (up to 2005) - Poverty spec was 48 spline (Hard tops / truck cabs that were not County spec) and everything else, CSW / XS / County were 36 spline
Post #212659 20th Feb 2013 4:10pm
The reason I know this is that when I built the SVX a like it was originally a base model truck cab (with a 48 spline steering column) and I wanted to fit an XS steering wheel to copy the genuine SVX, I had to buy a post 2008 wheel for it to fit (at great expense direct from LR)
Post #212661 20th Feb 2013 4:15pm
chipmunk
2012 Defender 90 Puma 2.2 HT Oslo Blue
Yes genuine, unmolested County spec. Would have the wheel in the unlikely event of being 48. Will check and let you know asap.
Ta.
Post #212663 20th Feb 2013 4:20pm
Thumbs Up
Post #212665 20th Feb 2013 4:25pm
ericvv
Now my head is spinning..... Laughing My SVX, a real one, surely has a 48 spline column You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #212676 20th Feb 2013 5:31pm
Correct Thumbs Up
But I would have saved myself a lot of money had I been able to fit an earlier XS steering wheel (identical in looks but not spline count to your SVX one)
Post #212678 20th Feb 2013 5:34pm
Page 2 of 2 <12
