Home > Technical > Koni shocks
Page 2 of 2 <12
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
Another Thumbs Up for Koni Heavy Tracks.
I got mine from Paddocks last summer - prices were considerably cheaper than Devon back then so check out both before buying. Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #212605 20th Feb 2013 10:26am
MartinK
Got mine from Defenderbits (site sponsor) competitive price, especially if you phone and mention defender2 Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #212611 20th Feb 2013 10:40am
farmer giles
i've put 100k miles on a set on my 300 tdi and had 1 broken eye in that time.
it still is the best ride/handling land rover that i have ever driven
Post #212614 20th Feb 2013 11:03am
jst
have now started to consider the OME sport too. it seems to be better for a heavier vehicle?
any experiences? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #213000 21st Feb 2013 5:35pm
Glynparry25
OME are great, I did consider them at the same time as the heavy track..... but then again I would have preferred the Koni Raids over the OME and HT... I guess it is all about your budget and exactly what driving you do. I have heard bad things about the OME sport when on the road without any load. I do like the fact you can adjust the Koni HT as it makes driving with and without a load as pleasurable.
Glyn Dog Sheep
Post #213004 21st Feb 2013 5:53pm
ericvv
Land Rover do not produce dampers themselves, anyone knows which brand and make they are using as original equipment for the Puma?
I am pretty happy with my original damper and shocks setup on the SVX, but also have heard that the SVX may be having a premium product compared with standard Station Wagons. All hearsay of course, and can obviously not compare with Koni's or other.
I may have to change the rear set up in the not too distant future as the Swiss MOT last Sep (first tech control which in Switzerland is at 4 years old) told me that my rear suspension was at the limit, still just ok, so I got a clear bill..... Next MOT is at 7 years, not sure I want to wait that long.
All a bit of a mistery, as got nothing in writing from them as to what "just within the limit" actually means, and when I told my dealer afterward, they obviosly downplayed it all.
Another question, is it normal that my SVX which never been used off road, which maybe 3 times in 4 years has been carrying a heavy load well within the tolerance, at 60k km is showing rear suspension fatigue? You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #213005 21st Feb 2013 6:08pm
geobloke
I am pretty sure Armstrong are the OEM manufacturer for Land Rover.
Post #213006 21st Feb 2013 6:21pm
Naks
I think it's actually Monroe --
Post #213179 22nd Feb 2013 9:46am
MartinK
I wonder how ther test them? I would expect many years and over 100k miles if used lightly. It could be that the bushings are the issue? Did they elaborate on whet the problem was?
My last Disco2 had it's original rear shocks for 10 years and 186000 miles, but I believe the bushings were replaced under warranty... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #213183 22nd Feb 2013 9:51am
Ady
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
I fitted Koni Heavy Tracks all round on my 300tdi Disco which I used for overland trips. Went all through the Atlas mountains and through the dunes in Sahara and they performed really. I was carrying a fair bit of extra weight, winch, rooftent etc.
I would highly recommend them and when the time comes to replace the ones on the Defender will be fitting Konis. Thumbs Up
Post #213221 22nd Feb 2013 12:29pm
Page 2 of 2 <12
