Home > Technical > How to fit xs side step/bars instructions?
Defender-Stu
Morning guys,
Could anyone help me with the fitting of some XS style side step/bars?, I'm looking for diagrams and also the part numbers for the bars that go from the steps to the chassis on my 90?
Stu
Post #212043 18th Feb 2013 7:00am
GUM97
This any use?
http://topix.landrover.jlrext.com/topix/co...View=false An engine to TDi for!
Post #212049 18th Feb 2013 8:06am
MartinK
This confused me when I fitted XS sidesteps to my County 110. So I went to the dealer and looked under a XS to see how they connected.
The 2 bars which connect from the step to the chassis go to a hole in the chassis where there's no obvious threaded hole (on a County) ...because it's expecting a rivnut.
I bought 4 x 12mm (M8 I think) stainless bolts with nyloc nuts, and bolted straight thru the chassis (there's a corresponding hole at the other side of the chassis rail). Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #212050 18th Feb 2013 8:13am
Porny
Site Sponsor
Stay is - DFE500100PMA about £10.50 each (2 needed - 1 per side)
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #212067 18th Feb 2013 9:32am
Defender-Stu
Hi Guys,
thanks for the help so far Thumbs Up
Porny i have found this and there is 4 bars?, is this right? as i thought it was just two and the ones that go to the front of the step is this correct?
Stu
Post #212086 18th Feb 2013 11:32am
Porny
Site Sponsor
Defender-Stu wrote:
Hi Guys,
Stu
As long as we are talking genuine part:
90 has two (one per step), 110 has 4 (2 per step).
Ian IRB
Post #212089 18th Feb 2013 11:42am
Defender-Stu
i think they are gen but i pick them up tonight so if need be i will fabricate the 2 rear supports if needs be as i bought the steps in mint condition for £65 Thumbs Up
here they are:
Stu
Post #212095 18th Feb 2013 11:55am
Porny
Site Sponsor
here they are:
Stu
They look genuine... the support goes at the front of the step - (left of picture) - you can just see the tab it bolts to (the bottom of the front curved bar).
Ian IRB
Post #212097 18th Feb 2013 12:09pm
Defender-Stu
Thanks Porny, been a great help as normal will post up how I get on Smile
What bolts will I need to fit these as dont come with any?
Stu
Post #212105 18th Feb 2013 12:35pm
MartinK
Stu
Factory or dealer fit is a rivnut in the chassis.
If yous isn't an XS, there won't be one.
You could either install a rivnut, or bolt right thru the chassis (which is what I did) using M8 x 110m bolts and nyloc nuts (with washers of course). Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #212118 18th Feb 2013 1:16pm
Rakthi
2011 Defender 110 Puma 2.4 HCPU Stornoway Grey
I have the fitting instructions for the 90 somewhere, if you PM me your email address I'll scan them in and mail them.
Post #212124 18th Feb 2013 1:31pm
Defender-Stu
Thanks for the email fella thats a Big help and i now see how they go on so will post up once they are fitted Thumbs Up
Post #212144 18th Feb 2013 2:45pm
f15hie
England 2013 Defender 90 Puma 2.2 XS CSW Havana
Not a great picture but you get the idea
Shows the bars fitted
A few posts to go
Post #212232 18th Feb 2013 8:28pm
Defender-Stu
Now fitted and all i need to do now is buy the support bars or make them myself and going to upgrade the nuts and bolts used, but cant grumble at £65 for gen LR Side Steps Thumbs Up :
Post #212297 19th Feb 2013 7:31am
Defender-Stu
MartinK wrote:
Stu
would these be the same as what would use on the front mounting points of the steering guard that goes through the chassis?
Post #212307 19th Feb 2013 8:01am
