Home > In Car Electronics > Just installed |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
16th Feb 2013 10:10pm |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 |
Good man and a nice piece of kit - Clarion of course! You'll appreciate the nice clear graphics and multiple iPhone connection options.
Just like mine Have you rigged up a camera yet? If you are on standard speakers a subwoofer is a good addition (I'd recommend the clarion srv) but there are other makes available apparently Dj Ps don't forget to put those two bolts in the dash! 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
16th Feb 2013 10:30pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
very smart CSK Automotive
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
16th Feb 2013 10:52pm |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 |
That looks great.
What is the 'lump' on top of the passenger side dash? |
17th Feb 2013 7:12am |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
looks awesome..... makes me miss mine.
Just as advice.... if on corrugations put the screen in. Mine lasted 3 years but then the bumps finally took its toll , has been a good reason for an upgrade though . Glyn |
17th Feb 2013 7:22am |
That's the GPS aerial. Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
17th Feb 2013 8:07am |
DarrenJ Member Since: 07 May 2012 Location: North Beds Posts: 312 |
Looks a nice set up Darren
17th Feb 2013 8:08am |
More info and pics on this particular unit here
http://www.defender2.net/forum/topic12571.html?highlight=clarion Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
17th Feb 2013 8:16am |
DJ,
But can I close the screen automatically when I switched off the Defender key??? Because or I switched off the unit (with the power button) or, if I use the ignitipn key, the unit switch off itself but the screen remain out...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
17th Feb 2013 8:49am |
Yes you can, in the settings menu you can choose auto for the screen. It will close when you turn off ignition, the downside is that it will always open as well IIRC which isn't always convenient. Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
17th Feb 2013 8:52am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20583 |
That's why with mine I always keep it closed unless in use and open and close manually. A. it can get in the way of the Hazard light switch and B. If you not expecting it with ignition on or the passenger it's at it's most vulnerable to be hit / damaged as it's in action.... Question - Does it not have variable illumination or green colour display? KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
17th Feb 2013 11:17am |
mhmmm doesn't work. with "auto for the screen" when I switch on the ignition (same "step" when the cabin fan goes on) the radio goes on and the monitor goes out, but when I switch off the ignition the radio goes off but the monitor stay out....... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
17th Feb 2013 9:48pm |
I'll check mine tomorrow , but I think you need to turn the key back to the first position until screen is closed then right off, if that makes sense.
But as Steve says its probably better to open it when you are ready, otherwise it might be in the way when you are not ready for it (like loading cup holders, wiping windows etc) But I have discovered that if it hits something on the way out (dog in my case) it will stop moving, then continue when you turn it on again Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
17th Feb 2013 10:14pm |
Whoops - me bad. Got that wrong its (as you have spotted) auto open, not auto open and close. I would have put money on it closing automatically but seems not. I turned that function off a year ago so memory dimmed I'm afraid
So it'll open when you turn on, but stay open when you switch off. A really handy feature then DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
18th Feb 2013 9:06am |
