Home > In Car Electronics > Suggestions for new radio
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Hi,
I'm looking for a new radio with the following functions:-
- Bluetooth phone connection
- Bluetooth audio
- DAB radio
- no CD
- screen that will show rear camera input
- single DIN
...I think that's it..!
Any suggestions..? All welcome, and I don't mind if you are biased..Wink
Simon
Post #211601 16th Feb 2013 8:37am
Re: Suggestions for new radio
Simon
Good to hear it! Thumbs Up What sort of price range are you looking for? The more the better. Whistle KEEP CALM AND Drill ON
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #211636 16th Feb 2013 11:12am
couplands
Preferably less than £300. Is that realistic..?
Simon
Post #211729 16th Feb 2013 6:36pm
Yes, Thumbs Up
Have a look at this and see what you think... The Kenwood KIV-700
Half your max budget but the BT unit is an extra £99 even then that's £250. Pretty damned good really. KEEP CALM AND Drill ON
Post #211806 16th Feb 2013 10:33pm
Plus free 1year warranty & free delivery. Mr. Green KEEP CALM AND Drill ON
Post #211807 16th Feb 2013 10:34pm
couplands
Thanks, looks good..Wink
I can't tell from the spec if the display can take an external camera input (for reversing camera)....do you know if it does..?
Thanks for your help.
Simon
Post #211815 16th Feb 2013 10:53pm
Here's some extra info:
http://www.kenwood-electronics.co.uk/produ.../KIV-700/#
I'll just check about the rear cam for you in a minute (PC's playing up a bit. Updates Rolling Eyes ) KEEP CALM AND Drill ON
Post #211817 16th Feb 2013 11:05pm
couplands
Did I miss the DAB capability too..?
Post #211819 16th Feb 2013 11:08pm
Yeah you did. There is DAB models but AFAIK you will then not be able to have the screen only the BT. Sooner or later there will probably be a unit with all of it built in especially as DAB comes in. Personally though unless you use the radio a lot I wouldn't bother.
As far as I can tell it's capable of taking AV in. It's difficult to tell looking though a whole ream of manual.
Thumbs Up KEEP CALM AND Drill ON
Post #211821 16th Feb 2013 11:20pm
BigRuss
What about this Alpine?
http://www.caraudiodirect.co.uk/alp-cde136...t-dab.html
its the model up from what land rover can now fit Thumbs Up Russell
2011MY 110 XS USW Black
Post #211829 17th Feb 2013 6:43am
couplands
Thanks Steve & Russ.
Seems I can't get all I want in one unit. I like DAB as I listen to Radio 5 a lot and its much better on digital than medium wave. I have it in my D4 and its brilliant. In fact if I could get my D4 unit in my 90 it would do everything in want..Wink
Simon
Post #211852 17th Feb 2013 8:48am
Not Alpine again. Thud Thud Thud Thud
On a different note. If it's a double DIN size unit in the D4 then I can't see why not. But you'd need a double DIN centre dash which isn't cheap and would also depend on if the unit in the D4 is specifically made for the D4's electrical system and not ISO standard as aftermarket radio's are. KEEP CALM AND Drill ON
Post #211878 17th Feb 2013 11:19am
couplands
I was joking about the D4 system. It's fully integrated and the display is separate from the receiver. Would be near impossible to fit, let alone the cost of it.. Shocked
I'll continue my quest...Wink
Simon
Post #212038 18th Feb 2013 12:04am
ZeDefender
In the same vein, does anyone know of a single DIN flip-up unit that looks like it belongs in a standard Defender? All the ones I've seen are all shiny with bright LED displays. I really like the understated "rugged" look of the OEM one, at least when the screen is closed...
Matt Tell someone you love them today because life is short.
Post #212044 18th Feb 2013 7:04am
a little off topic ... I put the OEM land rover unit back into my truck after the parrot unit died and connected it to the Focal sub woofer, and with standard speakers and the standard unit, I think it sounds fine, you won't get radio5 but maybe try adding a sub first and go from there ?
Post #212047 18th Feb 2013 7:40am
