![]() | Home > Td5 > Fuel pumps? |
As long as you use the Ninety 'frame' to keep the depth right, I can't see any reason why not.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6135 ![]() ![]() ![]() |
That's what I thought. cheers
So.... the disco Td5 fuel pump is exactly the same as a 90 (and I suspect a 110) pump, just the float arm is different... but they unclip, so it takes about 30 seconds to swap them over.
Handy tip! ![]() |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 ![]() ![]() ![]() |
Do you know the position in the floor that would needed to be cut to make a hatch to be able to remove a pump without removing the tank?
On a 90? Yes, got mine cut out with an inspection plate.
Will post up the dimensions tomorrow. |
Thanks, it's a job I always thought could be worthwhile.
Download .pdf for 110 Td5 tanks
Download .pdf for 90 tank The writing is in Italian.... that's 'coz I stole them off the interweb ages back. but you can see where the hole should go easily enough. I used an inspection plate from an old discover1 that was in the scrap yard. held in with 6 self tappers (into those locut plastic insert things)... although you could just screw straight into the floor plate if you wanted. The disco inspection plate is plenty big enough to get the Td5 pump up through. |
Can the hole be cut in the floor with the tank still in situ or does it need to be removed?
238kirk Member Since: 03 Nov 2012 Location: Doncaster Posts: 233 ![]() ![]() ![]() |
Yes but don't cut too deep as the pipes etc are under there, I used a grinder with a thin cutting blade and just cut through the surface, you've got at least 25mm to play with though |
If you cut through you'll remove one of the floor reinforcing secctions.
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
If you're careful you can cut a large enough inspection hole whilst retaining most of the reinforcing bar under the floor - You will need to cut 2/3 of it through though.
If you are cutting through with the tank in, as I did, put a piece of 3mm steel plate (or similar) between the tank and the floor first. You can feed the plate in from underneath if it's not too big. It still pays to be careful, only allowing the cutting blade to go through the floor by a few mm but will save you £££ if you do slip ! http://www.yorkshireoffroadclub.net/ |
Some pics of mine... (or Pam's !)
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I use a 300TDi Discovery in tank unit with an external pump in case it looks odd ! http://www.yorkshireoffroadclub.net/ Last edited by davew on 14th Feb 2013 11:18pm. Edited 1 time in total |
I assume thats a 110, the pump in the 90 is central, directly below the stiffener, isn't it?
![]() Last edited by Laurie on 14th Feb 2013 11:19pm. Edited 1 time in total |
No it's a 90.
I didn't use any measurements/templates, just cut a small (ish) hole central above the in tank unit - measuring from the rear and the side to get it's position. I then increased the hole outwards until I could fairly easily remove and replace the in tank unit through the hole. Hence I managed to avoid cutting through the floor strengtheners by having the hole offset slightly. Of course there are at least two types of TD5 90 fuel tank, I know they have different filler tube diameters, no guarantee that they both have the in tank unit in the same place ! Might be worth checking in case Land Rover did move the unit on later versus early tanks. http://www.yorkshireoffroadclub.net/ Last edited by davew on 14th Feb 2013 11:29pm. Edited 3 times in total |
